NS-F1000-K1000
2022-11-21提问
  • 0收藏,663浏览
请问如何重置设备,或重置密码。通过Console口连接NS-F1000-K1000防火墙。重启按CTRL+B,出如下提示,
Line con0 is available. Press ENTER to get started. System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU... Press Ctrl+T to start heavy memory test. Booting Normal Extended BootWare The Extended BootWare is self-decompressing....Done. **************************************************************************** * * * H3C SecPath BootWare, Version 3.03 * * * **************************************************************************** Copyright (c) 2004-2021 New H3C Technologies Co., Ltd. Compiled Date : Oct 22 2021 Memory Type : DDR3 SDRAM Memory Size : 2048MB Memory Speed : 667MHz Flash Size : 16MB Nandflash Size : 512MB PCB Version : Ver.A BootWare Validating... Press Ctrl+B to access EXTENDED-BOOTWARE MENU... Loading the main image files... Loading file flash:/f1010fw-cmw710-system-R8460P1609.bin.................... ............................................................................ ............................................................................ ................Done. Loading file flash:/f1010fw-cmw710-boot-R8460P1609.bin............Done. Image file flash:/f1010fw-cmw710-boot-R8460P1609.bin is self-decompressing.....Done. System image is starting... Cryptographic algorithms tests passed. Line con0 is available. Press ENTER to get started. Login: admin Password: AAA authentication failed. Login:
粉丝:158人 关注:8人
这是正常的启动记录,
出现这个提示的时候按下ctrl+B
粉丝:145人 关注:1人
这个时候狂按ctrl+B
zhiliao_3slLhB 知了小白
还有别的方法吗,手都要按费了,也不出来
