恢复S2100系列以太网交换机出厂时的缺省配置。需要注意的是此项操作要在重启交换机后才能生效。(重新启动交换机的具体操作可参见“10.4.2 重启交换机”)
操作 | 命令 | 说明 |
进入系统视图 | system-view | - |
恢复交换机缺省配置 | restore default | - |
例:恢复交换机缺省配置。
<H3C>system-view
Enter system view, return to user view with Ctrl+Z.
[H3C]restore default
This will restore the default configuration in the EEPROM memory
Are you sure?[Y/N]y
Now saving default configuration to EEPROM memory
Please wait for a while...
Default configuration saved to EEPROM memory successfully
(0)
· 使能密码恢复功能后不支持该操作。
· 关闭密码恢复功能后执行该操作,会删除设备存储介质中指定的下次启动配置文件。
在BootWare主菜单中,键入<5>,回车后,系统会恢复出厂设置并以空配置启动。
· 使能密码恢复功能后设置该项时的显示如下:
Enter your choice(0-9): 5
Password recovery capability is enabled. To perform this operation, first
disable the password recovery capability using the undo password-recovery
enable command in CLI.
· 关闭密码恢复功能后设置该项时的显示如下:
Because the password recovery capability is disabled, this operation can
cause the configuration files to be deleted, and the system will start up
with factory defaults. Are you sure to continue?[Y/N]Y
Setting...Done.
(0)
您好,执行reset saved-configuration
(0)
感谢回复,我进入boot menu 只有 BOOT MENU 1. Download application file with Xmodem 2. Modify bootrom password 3. Modify IP/Submask/Gateway address 4. Download application file with http 0. Reboot 这些,没有这些呢?
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
