S5560X_30C_EI堆叠断开
2022-11-24提问
  • 0收藏,658浏览
请问:
1、什么原因堆叠断开了?
2、是自动恢复的吗?
3、分裂保护起作用了吗?
Version:version 7.1.070, Release 1118P07
1/0/27、1/0/28
2/0/27、2/0/28是用3米的堆叠线连接的
irf-port 1/1
 port group interface Ten-GigabitEthernet1/0/27
 port group interface Ten-GigabitEthernet1/0/28
# irf-port 2/2
 port group interface Ten-GigabitEthernet2/0/27
 port group interface Ten-GigabitEthernet2/0/28
粉丝:171人 关注:8人
没有提供相关日志,无法准确回答问题。可以自己根据日志排查一下
1、什么原因堆叠断开了?
具体原因从日志里找找。
2、是自动恢复的吗?
如果没动那么就是自动恢复了,具体看下日志
3、分裂保护起作用了吗?
分裂了网络有没有问题,没问题就是起作用了
我下面贴出了告警,能不能麻烦您看下。
zhiliao_Fm3XDW 发表时间:2022-12-02
irf端口down了导致irf分裂,然后自动恢复了,排查一下irf端口down的原因吧
zhiliao_sEUyB 发表时间:2022-12-02
回复zhiliao_sEUyB:
请问如何排查irf端口down的原因?线缆直连的,没用光模块
不排除设备有问题,可以升级最新版本观察,或者收集诊断联系400处理
回复zhiliao_sEUyB:
谢谢!
zhiliao_Fm3XDW 知了小白
我上传了日志,不知道为啥没有显示出来。
%Oct 23 18:04:08:112 2022 H3C-S5560(IRF) STM/3/STM_LINK_DOWN: IRF port 2 went down.
%Oct 23 18:04:08:173 2022 H3C-S5560(IRF) HA/5/HA_STANDBY_TO_MASTER: Standby board in slot 2 changed to master.
%Oct 23 18:04:08:769 2022 H3C-S5560(IRF) DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on slot 1, type is MAIN_BOARD_TYPE_S5560X_30C_EI.
%Oct 23 18:04:09:193 2022 H3C-S5560(IRF) LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port GE1/0/15 of aggregation group BAGG1 changed to the inactive state, because the physical state of the port is down.
%Oct 23 18:04:09:194 2022 H3C-S5560(IRF) LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port GE1/0/16 of aggregation group BAGG1 changed to the inactive state, because the physical state of the port is down.
%Oct 23 18:04:09:259 2022 H3C-S5560(IRF) LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port GE1/0/17 of aggregation group BAGG2 changed to the inactive state, because the physical state of the port is down.
%Oct 23 18:04:09:334 2022 H3C-S5560(IRF) LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port GE1/0/18 of aggregation group BAGG3 changed to the inactive state, because the physical state of the port is down.
%Oct 23 18:04:09:414 2022 H3C-S5560(IRF) LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port GE1/0/19 of aggregation group BAGG4 changed to the inactive state, because the physical state of the port is down.
%Oct 23 18:04:09:492 2022 H3C-S5560(IRF) LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port GE1/0/20 of aggregation group BAGG5 changed to the inactive state, because the physical state of the port is down.
%Oct 23 18:04:10:508 2022 H3C-S5560(IRF) IFNET/3/PHY_UPDOWN: Physical state on the interface Vlan-interface10 changed to down.
%Oct 23 18:04:10:547 2022 H3C-S5560(IRF) IFNET/5/LINK_UPDOWN: Line protocol state on the interface Vlan-interface10 changed to down.
%Oct 23 18:05:10:416 2022 H3C-S5560(IRF) BFD/4/BFD_MAD_INTERFACE_CHANGE_STATE: BFD MAD function enabled on Vlan-interface10 changed to the faulty state.
%Oct 23 18:05:28:784 2022 H3C-S5560(IRF) IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet2/0/28 changed to up.
%Oct 23 18:05:28:786 2022 H3C-S5560(IRF) IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet2/0/28 changed to up.
%Oct 23 18:05:29:267 2022 H3C-S5560(IRF) IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet2/0/27 changed to up.
%Oct 23 18:05:29:269 2022 H3C-S5560(IRF) IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet2/0/27 changed to up.
%Oct 23 18:05:33:356 2022 H3C-S5560(IRF) STM/6/STM_LINK_UP: IRF port 2 came up.
%Oct 23 18:05:56:816 2022 H3C-S5560(IRF) DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on slot 1, type is MAIN_BOARD_TYPE_S5560X_30C_EI.
%Oct 23 18:05:57:735 2022 H3C-S5560(IRF) OPTMOD/4/MODULE_IN: -Slot=1; Ten-GigabitEthernet1/0/27: The transceiver is STACK_SFP_PLUS.
%Oct 23 18:05:57:759 2022 H3C-S5560(IRF) OPTMOD/4/MODULE_IN: -Slot=1; Ten-GigabitEthernet1/0/28: The transceiver is STACK_SFP_PLUS.
%Oct 23 18:06:01:633 2022 H3C-S5560(IRF) OPTMOD/4/MODULE_IN: -Slot=1; GigabitEthernet1/0/17: The transceiver is 1000_BASE_LX_SFP.
%Oct 23 18:06:01:892 2022 H3C-S5560(IRF) OPTMOD/4/MODULE_IN: -Slot=1; GigabitEthernet1/0/18: The transceiver is 1000_BASE_LX_SFP.
%Oct 23 18:06:02:153 2022 H3C-S5560(IRF) OPTMOD/4/MODULE_IN: -Slot=1; GigabitEthernet1/0/19: The transceiver is 1000_BASE_LX_SFP.
%Oct 23 18:06:02:410 2022 H3C-S5560(IRF) OPTMOD/4/MODULE_IN: -Slot=1; GigabitEthernet1/0/20: The transceiver is 1000_BASE_LX_SFP.
%Oct 23 18:06:10:551 2022 H3C-S5560(IRF) LLDP/5/LLDP_NEIGHBOR_AGE_OUT: Nearest bridge agent neighbor aged out on port GigabitEthernet2/0/14 (IfIndex 77), neighbor's chassis ID is 542b-de3f-3490, port ID is GigabitEthernet1/0/14.
%Oct 23 18:06:44:840 2022 H3C-S5560(IRF) LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port Ten-GigabitEthernet2/0/28 (IfIndex 91), neighbor's chassis ID is 542b-de3f-3490, port ID is Ten-GigabitEthernet1/0/27.
%Oct 23 18:06:44:863 2022 H3C-S5560(IRF) LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port Ten-GigabitEthernet2/0/27 (IfIndex 90), neighbor's chassis ID is 542b-de3f-3490, port ID is Ten-GigabitEthernet1/0/28.
%Oct 23 18:06:44:872 2022 H3C-S5560(IRF) HA/5/HA_BATCHBACKUP_STARTED: Batch backup of standby board in slot 1 started.
%Oct 23 18:06:44:874 2022 H3C-S5560(IRF) LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=1; Nearest bridge agent neighbor created on port Ten-GigabitEthernet1/0/27 (IfIndex 27), neighbor's chassis ID is 542b-de3f-3490, port ID is Ten-GigabitEthernet2/0/28.
%Oct 23 18:06:44:878 2022 H3C-S5560(IRF) LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=1; Nearest bridge agent neighbor created on port Ten-GigabitEthernet1/0/28 (IfIndex 28), neighbor's chassis ID is 542b-de3f-3490, port ID is Ten-GigabitEthernet2/0/27.
%Oct 23 18:06:44:896 2022 H3C-S5560(IRF) IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/27 changed to up.
%Oct 23 18:06:44:897 2022 H3C-S5560(IRF) IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/27 changed to up.
%Oct 23 18:06:44:898 2022 H3C-S5560(IRF) IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/28 changed to up.
%Oct 23 18:06:44:899 2022 H3C-S5560(IRF) IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/28 changed to up.
%Oct 23 18:06:45:067 2022 H3C-S5560(IRF) IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/20 changed to up.
%Oct 23 18:06:45:088 2022 H3C-S5560(IRF) BFD/5/BFD_CHANGE_FSM: Sess[192.168.100.1/192.168.104.254, LD/RD:155/131, Interface:GE1/0/18, SessType:Ctrl, LinkType:INET], Ver:1, Sta: DOWN->UP, Diag: 0 (No Diagnostic)
%Oct 23 18:06:45:115 2022 H3C-S5560(IRF) BFD/5/BFD_CHANGE_FSM: Sess[192.168.100.1/192.168.106.254, LD/RD:156/132, Interface:GE1/0/20, SessType:Ctrl, LinkType:INET], Ver:1, Sta: DOWN->UP, Diag: 0 (No Diagnostic)
%Oct 23 18:06:45:131 2022 H3C-S5560(IRF) BFD/5/BFD_CHANGE_FSM: Sess[192.168.100.1/192.168.105.254, LD/RD:157/133, Interface:GE1/0/19, SessType:Ctrl, LinkType:INET], Ver:1, Sta: DOWN->UP, Diag: 0 (No Diagnostic)
%Oct 23 18:06:45:135 2022 H3C-S5560(IRF) LAGG/6/LAGG_ACTIVE: Member port GE1/0/18 of aggregation group BAGG3 changed to the active state.
%Oct 23 18:06:45:162 2022 H3C-S5560(IRF) IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/19 changed to up.
%Oct 23 18:06:45:162 2022 H3C-S5560(IRF) IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/18 changed to up.
%Oct 23 18:06:45:188 2022 H3C-S5560(IRF) LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=1; Nearest bridge agent neighbor created on port GigabitEthernet1/0/20 (IfIndex 20), neighbor's chassis ID is 6893-2069-d29b, port ID is GigabitEthernet1/0/17.
%Oct 23 18:06:45:218 2022 H3C-S5560(IRF) LAGG/6/LAGG_ACTIVE: Member port GE1/0/19 of aggregation group BAGG4 changed to the active state.
%Oct 23 18:06:45:234 2022 H3C-S5560(IRF) LAGG/6/LAGG_ACTIVE: Member port GE1/0/20 of aggregation group BAGG5 changed to the active state.
%Oct 23 18:06:45:412 2022 H3C-S5560(IRF) LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=1; Nearest bridge agent neighbor created on port GigabitEthernet1/0/19 (IfIndex 19), neighbor's chassis ID is 6893-2069-c75b, port ID is GigabitEthernet1/0/17.
%Oct 23 18:06:45:492 2022 H3C-S5560(IRF) BFD/5/BFD_CHANGE_FSM: Sess[192.168.100.1/192.168.103.254, LD/RD:158/135, Interface:GE1/0/17, SessType:Ctrl, LinkType:INET], Ver:1, Sta: DOWN->UP, Diag: 0 (No Diagnostic)
%Oct 23 18:06:45:511 2022 H3C-S5560(IRF) IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/17 changed to up.
%Oct 23 18:06:45:511 2022 H3C-S5560(IRF) IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/18 changed to up.
%Oct 23 18:06:45:529 2022 H3C-S5560(IRF) LAGG/6/LAGG_ACTIVE: Member port GE1/0/17 of aggregation group BAGG2 changed to the active state.
%Oct 23 18:06:45:534 2022 H3C-S5560(IRF) IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/19 changed to up.
%Oct 23 18:06:45:535 2022 H3C-S5560(IRF) IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/20 changed to up.
%Oct 23 18:06:45:594 2022 H3C-S5560(IRF) LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=1; Nearest bridge agent neighbor created on port GigabitEthernet1/0/18 (IfIndex 18), neighbor's chassis ID is 9429-2f48-e7cb, port ID is Ten-GigabitEthernet1/0/28.
%Oct 23 18:06:45:671 2022 H3C-S5560(IRF) LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=1; Nearest bridge agent neighbor created on port GigabitEthernet1/0/17 (IfIndex 17), neighbor's chassis ID is 9429-2f48-9fcb, port ID is Ten-GigabitEthernet1/0/28.
%Oct 23 18:06:45:726 2022 H3C-S5560(IRF) IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/17 changed to up.
%Oct 23 18:06:45:875 2022 H3C-S5560(IRF) HA/5/HA_BATCHBACKUP_FINISHED: Batch backup of standby board in slot 1 has finished.
%Oct 23 18:06:47:136 2022 H3C-S5560(IRF) IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/3 changed to up.
%Oct 23 18:06:47:138 2022 H3C-S5560(IRF) IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/3 changed to up.
%Oct 23 18:06:47:211 2022 H3C-S5560(IRF) IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/1 changed to up.
%Oct 23 18:06:47:212 2022 H3C-S5560(IRF) IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/1 changed to up.
%Oct 23 18:06:47:307 2022 H3C-S5560(IRF) IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/14 changed to up.
%Oct 23 18:06:47:309 2022 H3C-S5560(IRF) LAGG/6/LAGG_ACTIVE: Member port GE1/0/15 of aggregation group BAGG1 changed to the active state.
%Oct 23 18:06:47:323 2022 H3C-S5560(IRF) IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/14 changed to up.
%Oct 23 18:06:47:347 2022 H3C-S5560(IRF) IFNET/3/PHY_UPDOWN: Physical state on the interface Vlan-interface10 changed to up.
%Oct 23 18:06:47:349 2022 H3C-S5560(IRF) IFNET/5/LINK_UPDOWN: Line protocol state on the interface Vlan-interface10 changed to up.
%Oct 23 18:06:47:351 2022 H3C-S5560(IRF) IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/15 changed to up.
%Oct 23 18:06:47:351 2022 H3C-S5560(IRF) IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/14 changed to up.
%Oct 23 18:06:47:354 2022 H3C-S5560(IRF) IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/14 changed to up.
%Oct 23 18:06:47:535 2022 H3C-S5560(IRF) LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port GigabitEthernet2/0/14 (IfIndex 77), neighbor's chassis ID is 542b-de3f-3490, port ID is GigabitEthernet1/0/14.
%Oct 23 18:06:47:539 2022 H3C-S5560(IRF) LAGG/6/LAGG_ACTIVE: Member port GE1/0/16 of aggregation group BAGG1 changed to the active state.
%Oct 23 18:06:47:596 2022 H3C-S5560(IRF) IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/15 changed to up.
%Oct 23 18:06:47:598 2022 H3C-S5560(IRF) IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/11 changed to up.
%Oct 23 18:06:47:599 2022 H3C-S5560(IRF) IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/11 changed to up.
%Oct 23 18:06:47:600 2022 H3C-S5560(IRF) IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/16 changed to up.
%Oct 23 18:06:47:675 2022 H3C-S5560(IRF) IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/16 changed to up.
%Oct 23 18:06:48:559 2022 H3C-S5560(IRF) LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=1; Nearest bridge agent neighbor created on port GigabitEthernet1/0/14 (IfIndex 14), neighbor's chassis ID is 542b-de3f-3490, port ID is GigabitEthernet2/0/14.
%Oct 23 18:07:10:394 2022 H3C-S5560(IRF) BFD/5/BFD_MAD_INTERFACE_CHANGE_STATE: BFD MAD function enabled on Vlan-interface10 changed to the normal state.
%Nov 10 11:34:30:762 2022 H3C-S5560(IRF) LAGG/6/LAGG_INACTIVE_PARTNER: Member port GE2/0/20 of aggregation group BAGG5 changed to the inactive state, because the aggregation configuration of its peer port is incorrect.
