VPN路由rt互引
2022-11-25提问
  • 0收藏,1208浏览
请教一个问题啊,关于同一个Leaf不同vrf使用RT互引实现路由互相引入,这个逻辑原理是什么样的?是必须借助Spine绕行传递协议报文实现的吗?
粉丝:35人 关注:7人
需要单独创建一个公共的VPN,然后配置路由复制并发布。
以下是VPN互引的参考配置案例,请参考:
组网如图:
FWMSR2建立OSPF邻居,与MSR2直连
FWg1/0/1属于vpn1g1/0/2属于VPN2
需求,通过动态路由的VPN互引实现MSR32.2.2.1可以访问MSR211.11.11.11
配置步骤
主要配置:
MSR2
interface GigabitEthernet0/0
 port link-mode route
 combo enable copper
 ip address 1.1.1.1 255.255.255.0
ospf 1
 import-route direct
 area 0.0.0.0
  network 1.1.1.0 0.0.0.255
ip route-static 2.2.2.0 24 1.1.1.2
FW
ip vpn-instance vpn1
 address-family ipv4
  route-replicate from vpn-instance vpn2 protocol direct
ip vpn-instance vpn2
 address-family ipv4
  route-replicate from vpn-instance vpn1 protocol direct advertise
  route-replicate from vpn-instance vpn1 protocol ospf 1 advertise
ospf 1 vpn-instance vpn1
 area 0.0.0.0
 combo enable copper
 ip binding vpn-instance vpn1
 ip address 1.1.1.2 255.255.255.0
 combo enable copper
 ip binding vpn-instance vpn2
 ip address 2.2.2.2 255.255.255.128
interface GigabitEthernet1/0/21
 combo enable copper
interface GigabitEthernet1/0/22
 combo enable copper
security-zone name Trust
 import interface GigabitEthernet1/0/1
security-zone name Untrust
 import interface GigabitEthernet1/0/2
security-policy ip
 rule 0 name 0
  action pass
  vrf vpn1
 rule 1 name 1
  action pass
  vrf vpn2
MSR2
 combo enable copper
 ip address 2.2.2.1 255.255.255.0
ip route-static 1.1.1.0 24 2.2.2.2
 ip route-static 11.11.11.0 24 2.2.2.2
实现效果:
MSR3上可以直接pingMSR2loopback地址 11.11.11.11
[MSR3]ping 11.11.11.11
Ping 11.11.11.11 (11.11.11.11): 56 data bytes, press CTRL+C to break
56 bytes from 11.11.11.11: icmp_seq=0 ttl=254 time=2.000 ms
56 bytes from 11.11.11.11: icmp_seq=1 ttl=254 time=0.000 ms
56 bytes from 11.11.11.11: icmp_seq=2 ttl=254 time=2.000 ms
56 bytes from 11.11.11.11: icmp_seq=3 ttl=254 time=0.000 ms
56 bytes from 11.11.11.11: icmp_seq=4 ttl=254 time=1.000 ms
--- Ping statistics for 11.11.11.11 ---
round-trip min/avg/max/std-dev = 0.000/1.000/2.000/0.894 ms
[MSR3]%Mar 16 15:23:32:968 2022 MSR3 PING/6/PING_STATISTICS: Ping statistics for 11.11.11.11: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 0.000/1.000/2.000/0.894 ms.
配置关键点
配置关键点:
route-replicate from { public | vpn-instance vpn-instance name } protocol
{ direct | static | { isis | ospf | rip } process-id } [advertise ]
vpn实例的IPv4 VPN视图下配置
忽略RT值(即VPN实例中不手工指定RT值),将公网或其他VPN实例的路由信息引入到指定VPN实例中
特别说明一点,公网的VPN有自己的VPN实例
ip public-instance
你好,我想确认rt互引方式的实现原理
风巡1990 发表时间:2022-11-26
RD是撤销路由的时候生效的,RT是决定接收路由的
https://zhiliao.h3c.com/Theme/details/195795
你好,我想确认rt互引方式实现的原理
