AC控制wx2540x-li配置wa5230-c-fit
2022-11-30提问
  • 0收藏,480浏览
我现在用poe交换连接上了AP,但是AP管理的AP是离线的。
粉丝:39人 关注:3人
AP是否拿到地址了,和ACping的通嘛
AP没有配置,我直接插上POE的
zhiliao_7Vc2Tl 发表时间:2022-11-30
4 个回答
粉丝:111人 关注:1人
自动上线开了吗?
已开启自动AP.和自动固化
粉丝:127人 关注:8人
dis wlan ap all看下状态
[H3C]display wlan ap all Total number of APs: 1 Total number of connected APs: 0 Total number of connected manual APs: 0 Total number of connected auto APs: 0 Total number of connected common APs: 0 Total number of connected WTUs: 0 Total number of inside APs: 0 Maximum supported APs: 128 Remaining APs: 128 Total AP licenses: 32 Local AP licenses: 32 Server AP licenses: 0 Remaining Local AP licenses: 32 Sync AP licenses: 0 AP information State : I = Idle, J = Join, JA = JoinAck, IL = ImageLoad C = Config, DC = DataCheck, R = Run, M = Master, B = Backup AP name APID State Model Serial ID 2F-AP04 1 I WA5320-C Not configured
检查一下AP有没有获取到IP地址
zhiliao_sEUyB 发表时间:2022-11-30
[H3C-GigabitEthernet1/0/1] [H3C-GigabitEthernet1/0/1]DIS IP INT BRIEF *down: administratively down (s): spoofing (l): loopback Interface Physical Protocol IP Address Description Vlan1 up up 169.254.47.0 -- [H3C-GigabitEthernet1/0/1]DISPLAY DHCP CLIENT Vlan-interface1 DHCP client information: Current state: SELECTING [H3C-GigabitEthernet1/0/1]DIS IP INT BRIEF
没有获到地址。是否可以直接设一个地址给它
可以,前提是得跟ac互通
才能上线
你在poe交换机上看看ap是否获取到了地址,Telnet登录ap看看,提示需要输入账号密码可能是ap胖模式,只让你输入密码是瘦ap模式,一般ac+ap下ap都是瘦模式。如果是胖模式Telnet到ap命令行改为瘦模式
zhiliao_7Vc2Tl 知了小白
我的POE交换机是普通交换机,看不到IP
