多分支节点通过PPPOE拨号,使用IPSec VPN连接访问总部
2022-12-01提问
  • 0收藏,525浏览
如果需要实现分支PPPOE拨号(是动态地址) 用IPSec VPN连接总部,这种方式一般怎么实现。后续增加的分支节点只需要更改账号密码就可以通过VPN连接到总部
!   -------1start------
hostname XXXX
enable password cisco
interface Virtual-Template1 type tunnel
 no ip address
 ip virtual-reassembly in
!   -------1end------
!   -------1.5start------
no ip domain lookup
ip domain name ***.***
username cisco password 0 cisco
crypto isakmp keepalive 20 5
!   -------1.5end------
!   -------2start------
crypto ipsec client ezvpn ez2
 connect auto
 group XXXX key XXXX
 local-address GigabitEthernet0/0
 mode network-extension
 peer X.X.X.X
 virtual-interface 1
 username xxxx password xxxx
 xauth userid mode local
crypto ipsec client ezvpn easyvpn1
 connect auto
 group unityclient key SEB711NECSI
 peer X.X.X.X
 username XXXX  password XXXX
 exit
!   -------3end------
interface GigabitEthernet0/1
 ip address 10.11.4.145 255.255.255.240
 ip nat inside
 ip tcp adjust-mss 1452
 crypto ipsec client ezvpn ez2 inside
 crypto ipsec client ezvpn easyvpn1 inside
 no sh
exit
!   -------2end------
interface GigabitEthernet0/0
 no sh
 ip address 192.168.10.11 255.255.255.0
 ip nat outside
 duplex auto
 speed auto
!   -------4end------
ip route 0.0.0.0 0.0.0.0 192.168.10.1
line con 0
 exec-timeout 5 0
 logging synchronous
 login local
 no modem enable
line aux 0
 exec-timeout 15 0
 login
line vty 0 4
 exec-timeout 5 0
 privilege level 15
 password cisco
 logging synchronous
 login
 transport input telnet
!--------------------------------------------exit
write
粉丝:20人 关注:15人
总部的用ipsec模板并且固定地址,分支地址变化都用fqdn的方式,总部不断增加节点对接对应的分支就可以了
