S5560X_30C_EI堆叠告警
2022-12-01提问
  • 0收藏,645浏览
请问下面的这些日志,设备出了什么问题,如有出了故障是什么原因?
H3C DEV/5/FAN_RECOVERED: Fan 2 recovered.
 %Oct 23 18:04:08:112 2022 H3C STM/3/STM_LINK_DOWN: IRF port 2 went down.
 %Oct 23 18:04:08:173 2022 H3C HA/5/HA_STANDBY_TO_MASTER: Standby board in slot 2 changed to master.
 %Oct 23 18:04:08:769 2022 H3C DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on slot 1, type is MAIN_BOARD_TYPE_S5560X_30C_EI.
 %Oct 23 18:04:09:193 2022 H3C LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port GE1/0/15 of aggregation group BAGG1 changed to the inactive state, because the physical state of the port is down.
 %Oct 23 18:04:09:194 2022 H3C LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port GE1/0/16 of aggregation group BAGG1 changed to the inactive state, because the physical state of the port is down.
 %Oct 23 18:04:09:259 2022 H3C LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port GE1/0/17 of aggregation group BAGG2 changed to the inactive state, because the physical state of the port is down.
 %Oct 23 18:04:09:334 2022 H3C LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port GE1/0/18 of aggregation group BAGG3 changed to the inactive state, because the physical state of the port is down.
 %Oct 23 18:04:09:414 2022 H3C LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port GE1/0/19 of aggregation group BAGG4 changed to the inactive state, because the physical state of the port is down.
 %Oct 23 18:04:09:492 2022 H3C LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port GE1/0/20 of aggregation group BAGG5 changed to the inactive state, because the physical state of the port is down.
 %Oct 23 18:04:10:508 2022 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Vlan-interface10 changed to down.
 %Oct 23 18:04:10:547 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface Vlan-interface10 changed to down.
 %Oct 23 18:05:10:416 2022 H3C BFD/4/BFD_MAD_INTERFACE_CHANGE_STATE: BFD MAD function enabled on Vlan-interface10 changed to the faulty state.
 %Oct 23 18:05:28:784 2022 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet2/0/28 changed to up.
 %Oct 23 18:05:28:786 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet2/0/28 changed to up.
 %Oct 23 18:05:29:267 2022 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet2/0/27 changed to up.
 %Oct 23 18:05:29:269 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet2/0/27 changed to up.
 %Oct 23 18:05:33:356 2022 H3C STM/6/STM_LINK_UP: IRF port 2 came up.
 %Oct 23 18:05:56:816 2022 H3C DEV/5/BOARD_STATE_NORMAL: Board state changed to Normal on slot 1, type is MAIN_BOARD_TYPE_S5560X_30C_EI.
 %Oct 23 18:05:57:735 2022 H3C OPTMOD/4/MODULE_IN: -Slot=1; Ten-GigabitEthernet1/0/27: The transceiver is STACK_SFP_PLUS.
 %Oct 23 18:05:57:759 2022 H3C OPTMOD/4/MODULE_IN: -Slot=1; Ten-GigabitEthernet1/0/28: The transceiver is STACK_SFP_PLUS.
 %Oct 23 18:06:01:633 2022 H3C OPTMOD/4/MODULE_IN: -Slot=1; GigabitEthernet1/0/17: The transceiver is 1000_BASE_LX_SFP.
 %Oct 23 18:06:01:892 2022 H3C OPTMOD/4/MODULE_IN: -Slot=1; GigabitEthernet1/0/18: The transceiver is 1000_BASE_LX_SFP.
 %Oct 23 18:06:02:153 2022 H3C OPTMOD/4/MODULE_IN: -Slot=1; GigabitEthernet1/0/19: The transceiver is 1000_BASE_LX_SFP.
 %Oct 23 18:06:02:410 2022 H3C OPTMOD/4/MODULE_IN: -Slot=1; GigabitEthernet1/0/20: The transceiver is 1000_BASE_LX_SFP.
 %Oct 23 18:06:10:551 2022 H3C LLDP/5/LLDP_NEIGHBOR_AGE_OUT: Nearest bridge agent neighbor aged out on port GigabitEthernet2/0/14 (IfIndex 77), neighbor's chassis ID is 542b-de3f-3490, port ID is GigabitEthernet1/0/14.
 %Oct 23 18:06:44:840 2022 H3C LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port Ten-GigabitEthernet2/0/28 (IfIndex 91), neighbor's chassis ID is 542b-de3f-3490, port ID is Ten-GigabitEthernet1/0/27.
 %Oct 23 18:06:44:863 2022 H3C LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port Ten-GigabitEthernet2/0/27 (IfIndex 90), neighbor's chassis ID is 542b-de3f-3490, port ID is Ten-GigabitEthernet1/0/28.
 %Oct 23 18:06:44:872 2022 H3C HA/5/HA_BATCHBACKUP_STARTED: Batch backup of standby board in slot 1 started.
 %Oct 23 18:06:44:874 2022 H3C LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=1; Nearest bridge agent neighbor created on port Ten-GigabitEthernet1/0/27 (IfIndex 27), neighbor's chassis ID is 542b-de3f-3490, port ID is Ten-GigabitEthernet2/0/28.
 %Oct 23 18:06:44:878 2022 H3C LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=1; Nearest bridge agent neighbor created on port Ten-GigabitEthernet1/0/28 (IfIndex 28), neighbor's chassis ID is 542b-de3f-3490, port ID is Ten-GigabitEthernet2/0/27.
 %Oct 23 18:06:44:896 2022 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/27 changed to up.
 %Oct 23 18:06:44:897 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/27 changed to up.
 %Oct 23 18:06:44:898 2022 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/28 changed to up.
 %Oct 23 18:06:44:899 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/28 changed to up.
 %Oct 23 18:06:45:067 2022 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/20 changed to up.
 %Oct 23 18:06:45:088 2022 H3C BFD/5/BFD_CHANGE_FSM: Sess[192.168.100.1/192.168.104.254, LD/RD:155/131, Interface:GE1/0/18, SessType:Ctrl, LinkType:INET], Ver:1, Sta: DOWN->UP, Diag: 0 (No Diagnostic)
 %Oct 23 18:06:45:115 2022 H3C BFD/5/BFD_CHANGE_FSM: Sess[192.168.100.1/192.168.106.254, LD/RD:156/132, Interface:GE1/0/20, SessType:Ctrl, LinkType:INET], Ver:1, Sta: DOWN->UP, Diag: 0 (No Diagnostic)
 %Oct 23 18:06:45:131 2022 H3C BFD/5/BFD_CHANGE_FSM: Sess[192.168.100.1/192.168.105.254, LD/RD:157/133, Interface:GE1/0/19, SessType:Ctrl, LinkType:INET], Ver:1, Sta: DOWN->UP, Diag: 0 (No Diagnostic)
 %Oct 23 18:06:45:135 2022 H3C LAGG/6/LAGG_ACTIVE: Member port GE1/0/18 of aggregation group BAGG3 changed to the active state. %Oct 23 18:06:45:162 2022 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/19 changed to up.
 %Oct 23 18:06:45:162 2022 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/18 changed to up.
 %Oct 23 18:06:45:188 2022 H3C LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=1; Nearest bridge agent neighbor created on port GigabitEthernet1/0/20 (IfIndex 20), neighbor's chassis ID is 6893-2069-d29b, port ID is GigabitEthernet1/0/17.
 %Oct 23 18:06:45:218 2022 H3C LAGG/6/LAGG_ACTIVE: Member port GE1/0/19 of aggregation group BAGG4 changed to the active state.
 %Oct 23 18:06:45:234 2022 H3C LAGG/6/LAGG_ACTIVE: Member port GE1/0/20 of aggregation group BAGG5 changed to the active state.
 %Oct 23 18:06:45:412 2022 H3C LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=1; Nearest bridge agent neighbor created on port GigabitEthernet1/0/19 (IfIndex 19), neighbor's chassis ID is 6893-2069-c75b, port ID is GigabitEthernet1/0/17.
 %Oct 23 18:06:45:492 2022 H3C BFD/5/BFD_CHANGE_FSM: Sess[192.168.100.1/192.168.103.254, LD/RD:158/135, Interface:GE1/0/17, SessType:Ctrl, LinkType:INET], Ver:1, Sta: DOWN->UP, Diag: 0 (No Diagnostic)
 %Oct 23 18:06:45:511 2022 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/17 changed to up.
 %Oct 23 18:06:45:511 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/18 changed to up.
 %Oct 23 18:06:45:529 2022 H3C LAGG/6/LAGG_ACTIVE: Member port GE1/0/17 of aggregation group BAGG2 changed to the active state.
 %Oct 23 18:06:45:534 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/19 changed to up.
 %Oct 23 18:06:45:535 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/20 changed to up.
 %Oct 23 18:06:45:594 2022 H3C LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=1; Nearest bridge agent neighbor created on port GigabitEthernet1/0/18 (IfIndex 18), neighbor's chassis ID is 9429-2f48-e7cb, port ID is Ten-GigabitEthernet1/0/28.
 %Oct 23 18:06:45:671 2022 H3C LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=1; Nearest bridge agent neighbor created on port GigabitEthernet1/0/17 (IfIndex 17), neighbor's chassis ID is 9429-2f48-9fcb, port ID is Ten-GigabitEthernet1/0/28.
 %Oct 23 18:06:45:726 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/17 changed to up.
 %Oct 23 18:06:45:875 2022 H3C HA/5/HA_BATCHBACKUP_FINISHED: Batch backup of standby board in slot 1 has finished.
 %Oct 23 18:06:47:136 2022 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/3 changed to up.
 %Oct 23 18:06:47:138 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/3 changed to up.
 %Oct 23 18:06:47:211 2022 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/1 changed to up.
 %Oct 23 18:06:47:212 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/1 changed to up.
 %Oct 23 18:06:47:307 2022 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/14 changed to up.
 %Oct 23 18:06:47:309 2022 H3C LAGG/6/LAGG_ACTIVE: Member port GE1/0/15 of aggregation group BAGG1 changed to the active state. %Oct 23 18:06:47:323 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/14 changed to up.
 %Oct 23 18:06:47:347 2022 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Vlan-interface10 changed to up.
 %Oct 23 18:06:47:349 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface Vlan-interface10 changed to up.
 %Oct 23 18:06:47:351 2022 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/15 changed to up.
 %Oct 23 18:06:47:351 2022 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/14 changed to up.
 %Oct 23 18:06:47:354 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/14 changed to up.
 %Oct 23 18:06:47:535 2022 H3C LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port GigabitEthernet2/0/14 (IfIndex 77), neighbor's chassis ID is 542b-de3f-3490, port ID is GigabitEthernet1/0/14.
 %Oct 23 18:06:47:539 2022 H3C LAGG/6/LAGG_ACTIVE: Member port GE1/0/16 of aggregation group BAGG1 changed to the active state. %Oct 23 18:06:47:596 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/15 changed to up.
 %Oct 23 18:06:47:598 2022 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/11 changed to up.
 %Oct 23 18:06:47:599 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/11 changed to up.
 %Oct 23 18:06:47:600 2022 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/16 changed to up.
 %Oct 23 18:06:47:675 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/16 changed to up.
 %Oct 23 18:06:48:559 2022 H3C LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=1; Nearest bridge agent neighbor created on port GigabitEthernet1/0/14 (IfIndex 14), neighbor's chassis ID is 542b-de3f-3490, port ID is GigabitEthernet2/0/14.
 %Oct 23 18:07:10:394 2022 H3C BFD/5/BFD_MAD_INTERFACE_CHANGE_STATE: BFD MAD function enabled on Vlan-interface10 changed to the normal state. of the port is down.
 %Oct 23 18:06:45:218 2022 H3C LAGG/6/LAGG_ACTIVE: Member port GE1/0/19 of aggregation group BAGG4 changed to the active state. %Oct 23 18:06:45:234 2022 H3C LAGG/6/LAGG_ACTIVE: Member port GE1/0/20 of aggregation group BAGG5 changed to the active state. %Oct 23 18:06:45:412 2022 H3C LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=1; Nearest bridge agent neighbor created on port GigabitEthernet1/0/19 (IfIndex 19), neighbor's chassis ID is 6893-2069-c75b, port ID is GigabitEthernet1/0/17.
 %Oct 23 18:06:45:529 2022 H3C LAGG/6/LAGG_ACTIVE: Member port GE1/0/17 of aggregation group BAGG2 changed to the active state. %Oct 23 18:06:45:534 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/19 changed to up.
 %Oct 23 18:06:45:875 2022 H3C HA/5/HA_BATCHBACKUP_FINISHED: Batch backup of standby board in slot 1 has finished. %Oct 23 18:06:47:136 2022 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/3 changed to up.
 %Oct 23 18:07:10:394 2022 H3C BFD/5/BFD_MAD_INTERFACE_CHANGE_STATE: BFD MAD function enabled on Vlan-interface10 changed to the normal state.tion group BAGG4 changed to the inactive state, because the physical state of the port is down.
 %Oct 23 18:06:45:535 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/20 changed to uH3C DEV/5/FAN_RECOVERED: Fan 2 recovered.
 %Oct 23 18:06:45:511 2022 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/17 changed to up. %Oct 23 18:06:45:511 2022 H3C IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/18 changed to up.
版本:版本 7.1.070, 版本 1118P07
1/0/27、1/0/28
2/0/27、2/0/28是用3米的堆叠线连接的
irf-port 1/1
 port group interface Ten-GigabitEthernet1/0/27
 port group interface Ten-GigabitEthernet1/0/28
irf-port 2/2
 port group interface Ten-GigabitEthernet2/0/27
 port group interface Ten-GigabitEthernet2/0/28
VLAN10 MAD BFD,1/0/14、2/0/14
BAGG2 1/0/17、2/0/17,光模块,有BFD检测
BAGG3 1/0/18、2/0/18,光模块,有BFD检测
BAGG3 1/0/19、2/0/19,光模块,有BFD检测
BAGG4 1/0/20、2/0/20,光模块,有BFD检测
粉丝:127人 关注:8人
检查一下堆叠链路的 功率情况
没有光模块,堆叠线缆是2根,2根都有问题?1根堆叠线缆正常irf可以正常工作吗?
zhiliao_Fm3XDW 发表时间:2022-12-02
1跟也可以,但是链路出问题,堆叠就分裂了
zhiliao_sEUyB 发表时间:2022-12-02
我的意思是有2根,即使有1根有问题也可以正常工作吧。请问 %Oct 23 18:04:08:112 2022 H3C STM/3/STM_LINK_DOWN: IRF port 2 went down. 是模块2 down了?模块1是master? 如果堆叠线缆有问题是不是应该模块1是master,我看日志象是模块2是master,是不是模块1主板出问题了?
是的。都down
irf主设备down了,备设备接替主设备了,
粉丝:1人 关注:3人
检查一下堆叠线缆模块是否正常
堆叠线缆是2根,2根都有问题?如1根正常irf可以正常工作吗?
