AP设备没有任何变化,为什么会出现一直掉线这种情况,什么原因呢?怎么配置AP或AC可以恢复。 2011-01-09 00:24:34
2022-12-02提问
  • 0收藏,528浏览
AP设备没有任何变化,为什么会出现一直掉线这种情况,什么原因呢?怎么配置AP或AC可以恢复。 2011-01-09 00:24:34 InformationalClient 2683-537f-8e88 went online from BSS 9428-2e8b-c234 with SSID wifi 0 on AP 9428-2e8b-c220. State changed to Run. 2011-01-09 00:24:35 InformationalClient 12fa-421f-bbb5 roamed from BSSID 307b-ac82-3980 on AP 307b-ac82-3980 of AC IP 127.0.0.1 to BSSID 48bd-3dcf-cfb0 on AP 48bd-3dcf-cfb0 of AC IP 127.0.0.1 successfully. 2011-01-09 00:24:35 InformationalClient 12fa-421f-bbb5 went offline from BSS 307b-ac82-3980 with SSID Public on AP 307b-ac82-3980. State changed to Unauth. Reason:Successfully roamed to another BSS. 2011-01-09 00:24:35 InformationalClient 12fa-421f-bbb5 went online from BSS 48bd-3dcf-cfb0 with SSID Public on AP 48bd-3dcf-cfb0. State changed to Run. 2011-01-09 00:24:35 InformationalDetected client IP change: Client MAC: 12fa-421f-bbb5, IP: 172.20.100.10, -NA-, -NA-, -NA-, Username: -NA-, AP name: 48bd-3dcf-cfb0, Radio ID: 1, Channel number: 11, SSID: Public, BSSID: 48bd-3dcf-cfb0. 2011-01-09 00:24:37 InformationalClient 9cbc-f0d8-909a went offline from BSS 307b-ac82-5a60 with SSID Public on AP 307b-ac82-5a60. State changed to Unauth. Reason:Successfully roamed to another BSS. 2011-01-09 00:24:37 InformationalDetected client IP change: Client MAC: 9cbc-f0d8-909a, IP: 172.20.100.30, 10.227.37.179, -NA-, -NA-, Username: -NA-, AP name: 9428-2e8b-c220, Radio ID: 2, Channel number: 11, SSID: Public, BSSID: 9428-2e8b-c230. 2011-01-09 00:24:37 InformationalClient 9cbc-f0d8-909a roamed from BSSID 307b-ac82-5a60 on AP 307b-ac82-5a60 of AC IP 127.0.0.1 to BSSID 9428-2e8b-c230 on AP 9428-2e8b-c220 of AC IP 127.0.0.1 successfully. 2011-01-09 00:24:37 InformationalClient 9cbc-f0d8-909a went online from BSS 9428-2e8b-c230 with SSID Public on AP 9428-2e8b-c220. State changed to Run.
AC ~接入交换机~AP
粉丝:127人 关注:8人
所有AP都掉线还是个别AP
刚开始是个别,现在是所有
zhiliao_9D3811 发表时间:2022-12-02
长ping一下ac看看链路稳定吗? 看下AC地址有没有冲突,到AP上看下日志
zhiliao_sEUyB 发表时间:2022-12-02
回复zhiliao_sEUyB:
长pingAC没有任何问题,AP 是FIT模式的,这个可以查看日志吗?
可以,远程或console到ap上面看
回复zhiliao_sEUyB:
WA2610H的型号,现在没有办法看到日志。
回复zhiliao_sEUyB:
请问现在这个AP日志的信息只能看到掉线上线,除此之外还有什么要注意的吗?
ap掉线可能性比较多。如果是大范围的掉线,先检查ac,找一下节点 从上往下排查,
