wap712c li 刷机问题
2022-12-04提问
  • 0收藏,867浏览
原来是fit想刷成fat,好像刷机包有问题。求刷机包。
刷机前:H3C WAP712C-LI BootWare, Version 7.20
Copyright (c) 2004-2020 New H3C Technologies Co., Ltd. Compiled Date : Jun 18 2020 CPU Type : ATHEROS AR9563 CPU L1 Cache : 32KB CPU Clock Speed : 775MHz Memory Type : SDRAM Memory Size : 128MB Memory Speed : 560MHz BootWare Size : 512KB Flash Size : 16MB PCB Version : Ver.A
刷机时候不小心按错成1Download Application Program To SDRAM And Run
现在ap上电开机:H3C WAP712C-LI BootWare, Version 1.06
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Compiled Date : Mar 27 2017 CPU Type : ATHEROS AR9563 CPU L1 Cache : 32KB CPU Clock Speed : 775MHz Memory Type : SDRAM Memory Size : 128MB Memory Speed : 560MHz BootWare Size : 512KB Flash Size : 16MB PCB Version : Ver.A
BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa4300s_fat.bin!.......... ............................................................................ ............................................................................ ........... The App file is self-decompressing.......................................... ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ...........................................................Done! System application is starting... Unknow equipment tag: WAP712C-LI, cannot initialize extra attribute. Not 8033 or 8035 PHY chip PHY_AR803X_Init at 462 Not 8033 or 8035 PHY chip PHY_AR803X_Init at 462
User interface con0 is available. Press ENTER to get started.
目前ctrl+y查看是fat模式。但搜不到h3c这个wifi。
粉丝:24人 关注:0人
试下
http://www.h3c.com/cn/Service/Document_Software/Software_Download/IP_Wlan/Cloud_AP_Series/H3C_WA4300S_OASIS/?CHID=369002&v=612
这个我试过了WA4300S-WPT330-R1113P19-OASIS版本,提示Something wrong with the file
zhiliao_Cy6YCe 发表时间:2022-12-04
这页面我下载过2个文件大小都是12.8M都提示出错,另一个不知道哪下载的文件10.7M可以刷,但刷完有问题
那应该不行
暮逍遥 发表时间:2022-12-04
刷机时候不要选1Download Application Program To SDRAM And Run,选2才能保留,否则重启就没有版本了
暮逍遥 发表时间:2022-12-04
问题是不小心已弄错了,目前找不到合适的刷机包。
好像没其他了,只能找客服要
暮逍遥 发表时间:2022-12-04
就是找不到客服,官网加了几个微信公众号什么的,就是找不到人
WA4300S-CMW520-R1509P01-FAT 目前是刷的这个包可以刷,但使用不了。哎,找个人工客服根本就找不到
可以尝试用21开头的序列号找客服
暮逍遥 发表时间:2022-12-04
这个应该不行,bootrom是7.0的。如果有其他在正常用的ap,将版本导出来,再导入这个,应该可以
暮逍遥 发表时间:2022-12-04
bootware刚想办法刷到7.20了,但引导文件刷不成,下载到ap文件目录后,重启提示 Loading the main boot and system image files... The system image does not exist! Loading the backup boot and system image files... The image does not exist! Booting image fails!
WA4300S-CMW520-R1509P01-FAT 能刷上去,但不能用。 WA4300S-WPT330-R1113P19-OASIS这个按2刷不了,手机下载到ap内存上,启动不了,提示不能引导 Loading the main boot and system image files... The system image does not exist! Loading the backup boot and system image files... The image does not exist! Booting image fails!
看能刷成5.0的bootware,再加载WA4300S-CMW520-R1509P01-FAT,如果还不行 可能就没办法了
暮逍遥 发表时间:2022-12-04
暮逍遥 发表时间:2022-12-04
有同样的ap,接上去看了下,但不知道怎么把里面配置文件下载到电脑
回复暮逍遥:
bootware刷到7.2最新的了,WA4300S-CMW520-R1509P01-FAT刷进去了,但引导不了。找同弄号ap看了下,里面有2个文件,一个bin另一个boot好像是引导的,有没办法把这2个文件下载到电脑呢
电脑搭建个ftp或者tftp服务器,在ap上put到电脑上
暮逍遥 发表时间:2022-12-04
同型号的ap看看bootware是哪个版本的,能保持一致最好
暮逍遥 发表时间:2022-12-04
回复暮逍遥:
主要是同型号是FIT模式的,想刷一个fat模式的,所以就成了这样
只能试试,有些ap是不支持fit模式的
暮逍遥 发表时间:2022-12-04
有些ap是不支持fatt模式的
暮逍遥 发表时间:2022-12-04
