H3C WA3010 忘记密码,
2022-12-17提问
  • 0收藏,772浏览
H3C WA3010 忘记密码,如何重设密码
https://zhiliao.h3c.com/questions/dispcont/176259
参考下
粉丝:119人 关注:1人
是wx吧
忘记密码直接console进去修改就行了,其它方法
https://www.h3c.com/cn/Service/Document_Software/Document_Center/Switches/Catalog/S5800/S5820X/Maintenance/Maintenance_Manual/H3C_DLMMHF(V1.01)/?CHID=123680
粉丝:35人 关注:7人
可以参考如下案例:
1.1.1  不需要之前的配置文件,恢复出厂设置
以下标黑部分为设备自动打印部分,标红加粗的命令是需要手动输入。
System is starting...
Press Ctrl D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing.......................Done!
BootWare Validating...
Press Ctrl B to enter extended boot menu...  //
如果看到该提示及时按Ctrl B进入botroom菜单
BotWare password: Not required. Please press Enter to Continue.
Password recovery capability is enabled.  //如果看到此提示,则表示设备开启了密码恢复功能。
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl Z: Access EXTEND-ASSISTANT MENU
Ctrl F: Format File System
Enter your choice(0-9):  //选择跳过配置文件
Flag Set Success.
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9):  //选择0重启设备
Press ENTER to get started.
跳过启动文件后直接保存当前配置,再重启
<H3C>save
The current Configuration will be written to the device. Are you sure? [Y/N]:y
(To leave the existing filename unchanged, press the enter key):(输入回车)
Configuration is saved to device successfully.
<H3C>reboot
Start to check Configuration with next startup Configuration file, please wait.........DONE!
Current Configuration may be lost after the reboot, save current Configuration? [Y/N]:y
重启完成后使用默认配置启动,恢复出厂成功
1.2  保留原有配置,只修改密码
本手册适用于如下产品:WAC360WAC 361、胖APWAP712CWAP722EWAP722SWAP722WAP621
1.2.1  以忽略系统当前配置的方式启动
详细配置过程:
Press Ctrl B to enter extended boot menu...//
Ctrl B进入botroom菜单
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Flag Set Success.
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
<H3C>dir  //查看设备配置文件:startup.cfg
Directory of flash:/
   2     -rw-      1666  Apr 26 2000 12:05:39   startup.cfg
29106 KB total (16876 KB free)
给设备和电脑配置成同网段Ip地址,举例:WAC配置成192.168.100.1/24,电脑配置成192.168.100.2/24),在电脑上使用3CDaemon软件搭建TFTP服务器,打开3CDaemon服务器,目录指向电脑E盘,然后点击应用。
<H3C>system
 [H3C]interface Vlan-interface 1
[H3C-Vlan-interface1]ip address 192.168.100.1 24
[H3C-Vlan-interface1]quit
[H3C]ping 192.168.100.2
  PING 192.168.100.2: 56  data bytes, press CTRL_C to break
    Reply from 192.168.100.2: bytes=56 Sequence=1 ttl=128 time=7 ms
 //提示设备到电脑网络可达
<H3C>tftp 192.168.100.2 put startup.cfg
//从设备上下载startup.cfg文件到电脑E
  File will be transferred in binary mode
  Sending file to remote TFTP server. Please wait... |
  TFTP:     1666 bytes sent in 0 seCond(s).
  File uploaded successfully.
下载成功:
可以到本地相关路径(此例子中是E盘)查看到相关文件。
解决方法:
使用记事本打开startup.cfg文件
删除aux0口下的认证方式和密码并保存文件
覆盖当前配置文件
<H3C>tftp 192.168.100.20 get startup.cfg
The file startup.cfg exists. Overwrite it? [Y/N]:y
  Verifying server file...
  Deleting the old file, please wait...
  Downloading file from remote TFTP server, please wait....
  TFTP:     1166 bytes received in 0 seCond(s)
  File downloaded successfully.
<H3C>reboot
Current Configuration may be lost after the reboot, save current Configuration? [Y/N]:n 不保存配置
This command will reboot the device. Continue? [Y/N]:y 确定继续重启
1.3  适用产品系列
本手册适用于如下产品:MSG360-4MSG360-10MSG360-10PMSG360-20MSG360-20NMSG360-40WAC380-30WAC380-60WAC380-90WAC380-120WAC381
1.4  保留原有配置,只修改密码
从设备中下载startup.cfg到电脑,具体参考:1.2保留原有配置,只修改密码
解决方法:
删除Con0口下的认证方式和密码并保存文件
覆盖当前配置文件
<H3C>tftp 192.168.100.2  get startup.cfg
<H3C>reboot
This command will reboot the device. Continue? [Y/N]:确定继续重启
