ipsec vpn 起不来ikev2
2022-12-24提问
  • 0收藏,864浏览
Dec 24 19:01:45:636 2022 FW IKEV2/7/EVENT: [IPsec->IKE] Get an IPsec SA acquire request. *Dec 24 19:01:45:637 2022 FW IKEV2/7/FSM: vrf = 0, src = 119.253.34.46, dst = 36.110.25.251/500 (Tunnel ID 833): (I) Current State: IDLE. *Dec 24 19:01:45:637 2022 FW IKEV2/7/FSM: vrf = 0, src = 119.253.34.46, dst = 36.110.25.251/500 Choose profile 1. *Dec 24 19:01:45:637 2022 FW IKEV2/7/FSM: vrf = 0, src = 119.253.34.46, dst = 36.110.25.251/500 Getting pre-shared key from profile keychain 1. *Dec 24 19:01:45:637 2022 FW IKEV2/7/FSM: vrf = 0, src = 119.253.34.46, dst = 36.110.25.251/500 Getting pre-shared key by address 36.110.25.251. *Dec 24 19:01:45:637 2022 FW IKEV2/7/FSM: vrf = 0, src = 119.253.34.46, dst = 36.110.25.251/500 Peer 1 matched. *Dec 24 19:01:45:637 2022 FW IKEV2/7/FSM: vrf = 0, src = 119.253.34.46, dst = 36.110.25.251/500 Search policy with vrf 0, local address 119.253.34.46. *Dec 24 19:01:45:637 2022 FW IKEV2/7/ERROR: vrf = 0, src = 119.253.34.46, dst = 36.110.25.251/500 Failed to find policy. *Dec 24 19:01:45:637 2022 FW IKEV2/7/EVENT: vrf = 0, src = 119.253.34.46, dst = 36.110.25.251/500 [IKE->IPsec] Send delete DPD request. *Dec 24 19:01:45:637 2022 FW IKEV2/7/FSM: vrf = 0, src = 119.253.34.46, dst = 36.110.25.251/500 (Tunnel ID 833): IKE SA deleted. %Dec 24 19:01:49:646 2022 FW IPSEC/6/IPSEC_SA_INITIATION: Began to establish IPsec SA. SA information: Local address: 119.253.34.46 Remote address: 36.110.25.251 Sour addr: 10.10.230.0/255.255.255.0 Port: 0 Protocol: IP Dest addr: 10.10.0.0/255.255.192.0 Port: 0 Protocol: IP Inside VPN instance: Outside VPN instance: ACL number: 3000 *Dec 24 19:01:49:646 2022 FW IKEV2/7/EVENT: [IPsec->IKE] Get an IPsec SA acquire request. *Dec 24 19:01:49:646 2022 FW IKEV2/7/FSM: vrf = 0, src = 119.253.34.46, dst = 36.110.25.251/500 (Tunnel ID 834): (I) Current State: IDLE. *Dec 24 19:01:49:646 2022 FW IKEV2/7/FSM: vrf = 0, src = 119.253.34.46, dst = 36.110.25.251/500 Choose profile 1. *Dec 24 19:01:49:646 2022 FW IKEV2/
ikve2起不来 之前起来过突然断了
粉丝:119人 关注:1人
----------------------------- Sequence number: 1 Mode: ISAKMP ----------------------------- Traffic Flow Confidentiality: Disabled Security data flow: 3000 Selector mode: standard Local address: 119.253.34.46 Remote address: 36.110.25.251 Transform set: 1 IKE profile: IKEv2 profile: 1 smart-link policy: SA trigger mode: Traffic-based SA duration(time based): 3600 seconds SA duration(traffic based): 5242880 kilobytes SA soft-duration buffer(time based): -- SA soft-duration buffer(traffic based): -- SA idle time: --
zhiliao_xJ9dSP 发表时间:2022-12-24
能给个解决思路嘛,真的不会了
参考下常见配置举例,看看有没有思路
叫我靓仔 发表时间:2022-12-24
zhiliao_xJ9dSP 知了小白
Sequence number: 1
Mode: ISAKMP
Transform set: 1
IKE profile:
IKEv2 profile: 1
smart-link policy:
SA idle time: --
粉丝:35人 关注:7人
IPSEC VPN故障排查:
1、检查公网地址的连通性
2、检查ipsec acl是否配置正确(两端ACL以互为镜像的方式配置)
3、检查ike keychain/ike profile 协商参数配置是否正确(工作模式、keychain、identity、本端/对端隧道地址或隧道名称、NAT穿越功能v7自适应)
4、检查ipsec proposal(v5平台) /ipsec  transform-set(v7平台)参数两端是否一致(封装模式、安全协议、验证算法、加密算法)
5、检查设备是否创建ipsec策略,并加载协商参数(acl、ike profile 、ipsec  transform-set、对端隧道IP)
6、检查ipsec策略是否应用在正确的接口上
IPSEC排查命令:
1、disp ipsec policy
2、disp acl
3、dis cu conf ike-profile
4、dis cu conf ike-keychain
5、display  ike proposal
6、display  ipsec  transform-set
7、disp ike sa (verbose)
8、disp ipsec sa
9、reset ipsec sa
10、reset ike sa
