HW
user-bind static ip-address 10.10.10.10 mac-address 94e1-ac1a-9e43 interface Eth-Trunk3 vlan 3989
我改的:arp static 10.10.10.10 94e1-ac1a-9e43 3989 Bridge-Aggregation 3
HW
acl name TCP 3001
我改的: acl advanced name TCP
HW
traffic classifier k1 operator and precedence 5
if-match acl TCP
traffic behavior k2
deny
traffic policy k3 match-order config
classifier k1 behavior k2
这个怎么改?
HW
traffic-filter vlan 3666 inbound acl name TCP
我改的:
interface Vlan-interface3666
packet-filter name TCP inbound
packet-filter name TCP outbound
HW
telnet client-source -a 192.168.1.254
我改的:telnet client source ip 192.168.1.254
(0)
从反馈的信息来看,应该是配置了QOS。
以下是QOS手册连接和配置举例:
https://www.h3c.com/cn/d_202210/1711248_30005_0.htm#_Toc117609357
Host通过接口Ten-GigabitEthernet1/0/1接入设备Device。
配置流量过滤功能,对接口Ten-GigabitEthernet1/0/1接收的目的端口号等于21的TCP报文进行丢弃。
图7-1 流量过滤基本组网图
# 定义高级ACL 3000,匹配目的端口号等于21的数据流。
[Device] acl advanced 3000
[Device-acl-ipv4-adv-3000] rule 0 permit tcp destination-port eq 21
[Device] qos policy policy
[Device-qospolicy-policy] classifier classifier_1 behavior behavior_1
[Device-qospolicy-policy] quit
# 将策略policy应用到端口Ten-GigabitEthernet1/0/1的入方向上。
[Device-Ten-GigabitEthernet1/0/1] qos apply policy policy inbound
(0)
控制从设备Switch A的GigabitEthernet1/0/1端口接收的所有报文,都转发到下一跳202.1.1.2。
图1-3 配置通过QoS策略实现IPv4策略路由组网图
# 创建IPv4 ACL,匹配规则为所有报文。
[SwitchA] acl number 2000
[SwitchA-acl-basic-2000] rule 0 permit source any
[SwitchA-acl-basic-2000] quit
# 创建流分类,并配置流分类规则为匹配IPv4 ACL 2000的报文。
[SwitchA] traffic classifier a
[SwitchA-classifier-a] if-match acl 2000
[SwitchA-classifier-a] quit
# 创建流行为,并配置动作为将报文重定向到下一跳202.1.1.2。
[SwitchA] traffic behavior a
[SwitchA-behavior-a] redirect next-hop 202.1.1.2
[SwitchA-behavior-a] quit
# 创建QoS策略,并将流分类与流行为进行关联。
[SwitchA] qos policy a
[SwitchA-qospolicy-a] classifier a behavior a
[SwitchA-qospolicy-a] quit
# 将QoS策略应用到端口GigabitEthernet1/0/1。
[SwitchA] interface gigabitEthernet 1/0/1
[SwitchA-GigabitEthernet1/0/1] qos apply policy a inbound
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
