h3c s5120v2 series
  • 0收藏,836浏览
如何恢复出厂设置?选了恢复出厂设置选项后提示Password recovery capability is enabled. To perform this operation, first disable the password recovery capability using the undo password-recovery enable command in CLI.,然后让我重新选择
粉丝:3人 关注:8人
这个不影响的,直接进命令行删除保存的配置就行了
3.2.2 清除保存的配置,重启设备方式恢复
#清除已保存的配置
<H3C>reset save
The saved configuration file will be erased. Are you sure? [Y/N]:Y
#重启设备
<H3C>reboot
 Start to check configuration with next startup configuration file, please wait.........DONE!
 This command will reboot the device. Current configuration will be lost, save current configuration? [Y/N]:n
 This command will reboot the device. Continue? [Y/N]:y
粉丝:145人 关注:1人
最简单的直接删除cfg+mdb文件
