wa5320-tif
2023-01-10提问
  • 0收藏,549浏览
粉丝:0人 关注:2人
  BootWare Validating... Press Ctrl+B to access EXTENDED-BOOTWARE MENU... Loading the main image files... Loading file flash:/wa5300-system.bin....................................... .....................................................................Done. Loading file flash:/wa5300-boot.bin.................................... Done. Image file flash:/wa5300-boot.bin is self-decompressing..................... ............................................................................ ............................................................................ ............................................................................ ............................................................................ ..............................Done. System image is starting... Startup configuration file does not exist. Line con0 is available. Press ENTER to get started. Loading file flash:/wa5300-boot.bin.................................... Done. Image file flash:/wa5300-boot.bin is self-decompressing..................... ............................................................................ ............................................................................ ............................................................................ ............................................................................ ..............................Done. System image is starting... Startup configuration file does not exist. Line con0 is available. Press ENTER to get started.
怎么进不了bootware
粉丝:144人 关注:1人
你按ctrl+b
在这个出来的时候及时按
粉丝:126人 关注:8人
这里提示的时候按ctrl+B
我也是这样操作的
zhiliao_fzi50v 发表时间:2023-01-10
设备没事别到你按了ctrl+b,一个是按的时机不对,还有就是console兼容问题,没有发送出去,可以把console软件设置一下再重启ctrl B试试,具体设置看答案里的图片
zhiliao_sEUyB 发表时间:2023-01-10
不行还是进不去
启动起来后 敲回车 有反应吗? 能正常输入命令吗
可以输命令
那还是ctrl+B时机不对,还会提示ctrl+d的,ctrl+d 能进去么
进去了
==========================<ETHERNET PARAMETER SET>========================== |Note: '.' = Clear field. | | '-' = Go to previous field. | | Ctrl+D = Quit. | ============================================================================ Protocol (FTP or TFTP) :tftp Load File Name :apwa5300_v7.19.btw :apwa5300_v7.19.btw Target File Name :apwa5300_v7.19.btw :apwa5300_v7.19.btw Server IP Address :192.168.0.2 Local IP Address :192.168.0.8 Subnet Mask :255.255.255.0 Gateway IP Address :0.0.0.0 ===================<BOOTWARE OPERATION ETHERNET SUB-MENU>=================== |<1> Update Full BootWare | |<2> Update Extended BootWare | |<3> Update Basic BootWare | |<4> Modify Ethernet Parameter | |<0> Exit To Main Menu | ============================================================================ Enter your choice(0-4): 4 ==========================<ETHERNET PARAMETER SET>========================== |Note: '.' = Clear field. | | '-' = Go to previous field. | | Ctrl+D = Quit. | ============================================================================ Protocol (FTP or TFTP) :tftp Load File Name :apwa5300_v7.19.btw :WA5300-OASIS.ipe Target File Name :apwa5300_v7.19.btw :WA5300-OASIS.ipe Server IP Address :192.168.0.2 Local IP Address :192.168.0.8 Subnet Mask :255.255.255.0 Gateway IP Address :0.0.0.0 ===================<BOOTWARE OPERATION ETHERNET SUB-MENU>=================== |<1> Update Full BootWare | |<2> Update Extended BootWare | |<3> Update Basic BootWare | |<4> Modify Ethernet Parameter | |<0> Exit To Main Menu | ============================================================================ Enter your choice(0-4): 2 Loading...Failed! ===================<BOOTWARE OPERATION ETHERNET SUB-MENU>=================== |<1> Update Full BootWare | |<2> Update Extended BootWare | |<3> Update Basic BootWare | |<4> Modify Ethernet Parameter | |<0> Exit To Main Menu | ============================================================================ Enter your choice(0-4): 1 Loading...Failed! ===================<BOOTWARE OPERATION ETHERNET SUB-MENU>=================== |<1> Update Full BootWare | |<2> Update Extended BootWare | |<3> Update Basic BootWare | |<4> Modify Ethernet Parameter | |<0> Exit To Main Menu | ============================================================================ Enter your choice(0-4):
刷不了
刷胖版本? 参考版本说明书里面有操作流程
升级不了bootware
zhiliao_fzi50v 发表时间:2023-01-11
需要bootware包
zhiliao_sEUyB 发表时间:2023-01-11
有boot包了呀
粉丝:22人 关注:0人
这个界面出现的很快,最好是重启时候就一直按ctrl+B,不然就过去了,再按就没用了。
按了呀,进不去
