3par更换硬盘
2023-01-13提问
  • 0收藏,1536浏览
ZD_QK 二段
粉丝:2人 关注:0人
3par更换硬盘后
servicemag status -d输入如下
Cage 1, magazine 18:
The magazine is being brought online due to a servicemag resume.
The last status update was at Fri Jan 13 17:12:30 2023.
The command started at Fri Jan 13 17:12:28 2023
Chunklets relocated: 9 in 2 minutes and 33 seconds
Chunklets remaining: 8661
Chunklets marked for moving: 8661
Estimated time for relocation completion based on 17 seconds per chunklet is: 1 days, 16 hours, 53 minutes and 57 seconds
The cumulative output so far is:
servicemag resume 1 18
... mag 1 18 already onlooped
.. firmware is current on pd WWN [5000C500AEF5FEE8] Id [40]
 ... firmware is current on pd WWN [5000C500ADF835A4] Id [38]
 ... checking for valid disks...
 ... disks in mag : 1 18
. normal disks: WWN [5000C500AEF5FEE8] Id [40] diskpos [0]
 ... not normal disks: WWN [5000C500ADF835A4] Id [38]
 ... verifying spare space for disks 38 and 40
 ... playback chunklets from pd WWN [5000C500AEF5FEE8] Id [40]
 ... All chunklets played back / relocated.
.. cleared logging mode for cage 1 mag 18
... relocating chunklets from spare space
使用showpd -c查看
38 1:18:0? NL failed 3611 0 0 0 0 2896 715 0 0 0 0 0
39 1:19:0 NL normal 3611 2893 0 469 0 0 0 164 0 85 0 0
 40 1:18:0 NL normal 3611 2896 0 0 0 715 0 0 0 0 0 0
38和40都是1:18:0 是不是等区块搬迁完成后序号38就会消失?
粉丝:24人 关注:0人
新版本的3PAR自动执行servicemag start,用pdid做参数,servicemag resume完成后,旧的硬盘会被自动dismiss。
如果手动执行servicemag start, 并且使用cage id, mag id参数,sercicemag resume完成后,需要手动执行dismiispd。
z6Kl9 九段
粉丝:66人 关注:2人
这个找400看一下
粉丝:22人 关注:0人
没消失就dismisspd 38
粉丝:6人 关注:15人
同步完成后38号会自动消除,40号会显示正常。38号是之前坏的硬盘序号,同步完成后一般会自己消除。
