wa5320-c ap-mode fit 无法切换瘦模式,已更新最新版本
2023-01-17提问
  • 0收藏,572浏览
[H3C]ap-mode fit Changing working mode will reboot system. Continue? [Y/N]:y Operation failed. No image file was found for the AP mode or the AP model does not support the specified mode. [H3C]Operation failed. No image file was found for the AP mode or the AP model d oes not support the specified mode.Operation failed. No image file was found for the AP mode or the AP model does not support the specified mode.Operation faile d. No image file was found for the AP mode or the AP model does not support the specified mode. 系统版本: [H3C]display version H3C Comware Software, Version 7.1.064, Release 2449P11 Copyright (c) 2004-2021 New H3C Technologies Co., Ltd. All rights reserved. H3C WA5320-C uptime is 0 weeks, 0 days, 0 hours, 16 minutes Last reboot reason : Power on Boot image: flash:/wa5300-oasis-boot.bin Boot image version: 7.1.064, Release 2449P11 Compiled Nov 17 2021 16:00:00 System image: flash:/wa5300-oasis-system.bin System image version: 7.1.064, Release 2449P11 Compiled Nov 17 2021 16:00:00 with 1 ARM 710MHz Processor 256M bytes DDR3 32M bytes NorFlash Memory Hardware Version is Ver.B Basic Bootrom Version is 7.27 Extend Bootrom Version is 7.28 [Subslot 0]H3C WA5320-C Hardware Version is Ver.B [SLOT 1]GE1/0/1 (Hardware)Ver.B, (Driver)1.0 [SLOT 1]GE1/0/2 (Hardware)Ver.B, (Driver)1.0 [SLOT 1]RADIO1/0/1 (Hardware)Ver.B, (Driver)1.0 [SLOT 1]RADIO1/0/2 (Hardware)Ver.B, (Driver)1.0
粉丝:9人 关注:6人
进到ctrl+b然后切换瘦模式试试
粉丝:7人 关注:6人
没有瘦版本镜像文件
粉丝:171人 关注:8人
直接把镜像删了就行,或者参考:
AP胖切瘦配置案例方法-V7
