[MSR930]display current-configuration
version 5.20, Release 2514P10
sysname MSR930
l2tp enable
nat address-group 0 121.69.113.* 121.69.113.*
domain default enable system
dns proxy enable
dar p2p signature-file flash:/p2p_default.mtd
port-security enable
web idle-timeout 60
password-recovery enable
acl number 2000
rule 15 permit source 10.0.0.0 0.0.0.255
vlan 1
domain system
authentication ppp local
access-limit disable
state active
idle-cut disable
self-service-url disable
ip pool 1 192.168.0.2 192.168.0.100
dhcp server ip-pool dhcp-server
network 10.0.0.0 mask 255.255.255.0
network ip range 10.0.0.101 10.0.0.199
gateway-list 10.0.0.1
dns-list 211.167.230.100 211.167.230.200
user-group system
group-attribute allow-guest
local-user admin
password cipher $c$3$Mh3bMwcCwDwpIk6+wAPHnzSwK7vhfSV/UFXF2
authorization-attribute level 3
service-type ssh
service-type web
local-user tiger
password cipher $c$3$dckVDwDUTHVHIMLa/lJJZ+pJX0l7RJ5vW
service-type ssh
local-user vpdnuser
password cipher $c$3$ko1DzQVBDDRNcynfhkqQgIUve24o7HFbq
service-type ppp
cwmp
undo cwmp enable
l2tp-group 1
allow l2tp virtual-template 1
tunnel name LNS
interface Aux0
async mode flow
link-protocol ppp
interface Cellular0/0
async mode protocol
link-protocol ppp
interface Virtual-Template1
ppp authentication-mode chap domain system
remote address pool 1
ip address 192.168.0.1 255.255.255.0
interface NULL0
interface Vlan-interface1
ip address 10.0.0.1 255.255.255.0
interface GigabitEthernet0/0
port link-mode route
nat outbound 2000 address-group 0
ip address 121.69.113.* 255.255.255.*
dns server 211.167.230.100
dns server 211.167.230.200
interface GigabitEthernet0/1
port link-mode bridge
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
ip route-static 0.0.0.0 0.0.0.0 121.69.113.*
dhcp server forbidden-ip 10.0.0.200 10.0.0.254
dhcp enable
ssh server enable
nms primary monitor-interface GigabitEthernet0/0
load xml-configuration
load tr069-configuration
user-interface tty 12
user-interface aux 0
user-interface vty 0 4
authentication-mode scheme
return
主机拨入成功,可访问内部网络,但网关为0.0.0.0,如何配置使拨入成功的主机访问内网的同时还可以访问外网
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
