WX3510H控制 AP无法找到AC(ap获取了IP地址)
2017-08-20提问
  • 1收藏,3881浏览
下文 零段
*                 H3C WA4330-ACN BootWare, Version 1.12                    *
Copyright (c) 2004-2016 Hangzhou H3C Technologies Co., Ltd.
Compiled Date       : Jun 28 2016
CPU Type            : ATHEROS AR9557
CPU L1 Cache        : 32KB
CPU Clock Speed     : 720MHz
Memory Type         : SDRAM
Memory Size         : 256MB
Memory Speed        : 560MHz
BootWare Size       : 512KB
Flash Size          : 32MB
PCB Version         : Ver.B
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
Starting to get the main application file--flash:/wa4300_fit.bin!
The main application file does not exist--flash:/wa4300_fit.bin!
Starting to get the backup application file--flash:/backup.bin!
The backup application file does not exist--flash:/backup.bin!
Starting to get the secure application file--flash:/secure.bin!
The secure application file does not exist--flash:/secure.bin!
Booting App fails!
Trying to get the IP address from the DHCP server......
DHCP server's IP address is 192.168.6.100
Client's assigned address is 192.168.6.103
DNS domain name got from DHCP server is
DNS server's IP address is 192.168.6.100
Default Gateway's IP address is 192.168.6.100
This client's subnet mask is 255.255.255.0
The length of option 43 is: 0
 Change State : Idle to Broadcast Discovery
 Change State : Broadcast Discovery to Unicast Discovery
get ac [***.***]'s ip...
Getting AC's IP Address Failed...
 Change State : Unicast Discovery to Sulking
 Can't download the image from network, please check the network settings
 The system will reboot
 [State : Idle] Reset request, rebooting the AP
Rebooting......
如上是廋AP无法找到AC的控制台信息,其中AC和AP直连,且是二层(vlan 6)互通。
假设将我的笔记本接到AP所接的AC的端口,笔记本是可以正常获取IP,也可以ping通AC。
其中AC接AP的端口配置如下:
[WX3510H]
interface GigabitEthernet1/0/2    //直连AP的端口
 port link-type trunk
 undo port trunk permit vlan 1
 port trunk permit vlan 2 to 4094
 port trunk pvid vlan 6
问题出在哪里呢?   求大神帮忙。
SRv6 五段
粉丝:4人 关注:2人
日志来看ac没有响应,互通性已经没有问题。还是看看你ac上的日志或者debug lwapp
非常感谢您,我明天看看日志,并及时反馈出来。谢谢!
下文 发表时间:2017-08-20
非常感谢,是没有license导致AP没法上线的,导入license后就正常了。再次表示感谢。
下文 发表时间:2017-08-21
长者 四段
粉丝:1人 关注:1人
AC有license吗?
非常感谢,确实是没有license导致AP没法上线的,导入license后就正常了。再次表示感谢。
下文 发表时间:2017-08-21
下文 知了小白
谢谢两位的帮助。
最终是因为没有license导致AP没法上线的。
