华三S12504接口缓冲区占用过大
2023-02-03提问
  • 0收藏,636浏览
设备Log发现异常信息
WARNING: Packets sent from chip 0 on chassis 2 slot 0 to port XGE2/0/0/39 on chassis 2 slot 0 have used over 90% of the buffer.
The CoS field for these packets is 2.
%Dec 28 23:17:58:933 2022 CFT08_IN_Stack_SW DRVPLAT/2/DrvDebug: -Chassis=2-Slot=0;
请问导致该异常log是怎么发生的?会有什么影响吗?该如何解决呢?
hi,该问题可能是存在流量瞬间拥塞,从slot 0 chip 0芯片端口进来的流量突发到了XGE2/0/0/39导致buffer告警,如果是单纯拥塞了,扩容端口可以解决
