S7003X IRF堆叠告警
2023-02-11提问
  • 0收藏,814浏览
如下日志告警,交换机堆叠断开,端口显示down
Physical state on the interface Ten-GigabitEthernet1/0/0/27 changed to down.
然后紧接着板卡出现告警
Board state changed to Fault on chassis 2 slot 0, type is LSCM2CGP24TSSC8.
Board was removed from chassis 2 slot 0, type is unknown
请问下这样是堆叠线断开会导致交换机的板卡出现告警么,还是板卡的故障导致的堆叠断开
%Feb 10 04:46:33:406 2023 S7003X-3F STM/3/STM_PHY_DOWN: Physical interface Ten1/0/0/27 of IRF port 2 went down.
 %Feb 10 04:46:33:414 2023 S7003X-3F IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/0/27 changed to down.
%Feb 10 04:46:33:416 2023 S7003X-3F IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/0/27 changed to down.
 %Feb 10 04:46:33:458 2023 S7003X-3F STM/3/STM_PHY_DOWN: Physical interface Ten1/0/0/28 of IRF port 2 went down.
%Feb 10 04:46:33:461 2023 S7003X-3F STM/3/STM_LINK_DOWN: IRF port 2 went down.
%Feb 10 04:46:33:593 2023 S7003X-3F STM/3/STM_PHY_DOWN: Physical interface Ten1/0/0/28 of IRF port 2 went down.
 %Feb 10 04:46:33:540 2023 S7003X-3F DEV/2/BOARD_STATE_FAULT: Board state changed to Fault on chassis 2 slot 0, type is LSCM2CGP24TSSC8.
%Feb 10 04:46:33:595 2023 S7003X-3F LAGG/6/LAGG_INACTIVE_NODEREMOVE: Member port GE2/0/0/24 of aggregation group BAGG24 changed to the inactive state, because the card that hosts the port was absent.
%Feb 10 04:46:33:626 2023 S7003X-3F LAGG/6/LAGG_INACTIVE_NODEREMOVE: Member port XGE2/0/0/26 of aggregation group BAGG26 changed to the inactive state, because the card that hosts the port was absent.
%Feb 10 04:46:33:669 2023 S7003X-3F IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/0/28 changed to down.
 %Feb 10 04:46:33:687 2023 S7003X-3F IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/0/28 changed to down.
 %Feb 10 04:46:33:707 2023 S7003X-3F DEV/3/BOARD_REMOVED: Board was removed from chassis 2 slot 0, type is unknown.
粉丝:104人 关注:1人
堆叠线缆断开不会导致板卡无法识别。
看日志时间相差不大,都4点46分33秒的日志,设备上报日志有先后顺序。应该板卡故障导致的堆叠分裂。
粉丝:31人 关注:26人
告警是说成员设备2的0号板卡状态进入到fault状态 也就是板卡出现了故障 结合你的前面的1/0/0/27接口故障 说明是成员2的0号板卡故障导致的接口down了
