H3C S5024P-EI 如何恢复出厂设置
2023-02-20提问
  • 0收藏,1065浏览
粉丝:171人 关注:8人
命令行恢复出厂设置
reset saved-configuration
The saved configuration file will be erased. Are you sure? [Y/N]:Y  //确定删除保存的配置文件
reboot
 Start to check configuration with next startup configuration file, please wait.........DONE!
 This command will reboot the device. Current configuration will be lost, save current configuration? [Y/N]:N  //不保存配置
This command will reboot the device. Continue? [Y/N]:Y   //继续重启
粉丝:15人 关注:2人
<H3C>reset saved-configuration
y
<H3C>reboot     //重启后第一个提示是否保存,选择N,第二个提示是否重启,选择Y
n
y
