%Feb 23 12:27:29:968 2023 Core_SR8816-X IFMON/4/OUTPUT_BUFFER_DROP_THRESHOLD: -Chassis=1-Slot=4; The number of output buffer drop packets exceeded the high threshold: Interface name=GigabitEthernet1/4/4/3, upper threshold 1000, lower threshold 100, number of output buffer drop packets 1078, Interval 10s. %Feb 23 12:26:20:218 2023 Core_SR8816-X IFMON/4/OUTPUT_BUFFER_DROP_RECOVERY: -Chassis=1-Slot=4; The number of output buffer drop packets dropped the lower threshold: Interface name=Ten-GigabitEthernet1/4/2/1, upper threshold 1000, lower threshold 100, number of output buffer drop packets 0, Interval 10s.
路由器出现这种告警是什么原因导致的?
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
input比较小。output达到60%%甚至更高
嗯,告警里也是output方向,看看出方向流量正不正常
有没有肯是路由环路?
不好说,也可以看下其他接口的入,和这个接口的出,流量是否对等,如果这个口是出口,他的出流量=其他接口入流量之和,再看看那个接口入方向比较多,看看是不是网络里有终端中毒了
