路由器日志经常出现这种日志,是什么原因导致的,需要如何处理
2023-02-28提问
  • 0收藏,1202浏览
%Feb 28 08:33:52:955 2023 SR8816-X NTP/5/NTP_STRATUM_CHANGE: System stratum changed from 4 to 3 after clock update. %Feb 28 08:33:52:955 2023 SR8816-X NTP/5/NTP_SOURCE_CHANGE: NTP server's IP address changed from 210.34.0.10 to 210.34.0.11. %Feb 28 08:05:48:952 2023 SR8816-X NTP/5/NTP_STRATUM_CHANGE: System stratum changed from 16 to 4 after clock update. %Feb 28 08:05:48:952 2023 SR8816-X NTP/5/NTP_LEAP_CHANGE: System Leap Indicator changed from 3 to 0 after clock update. %Feb 28 08:05:48:950 2023 SR8816-X NTP/5/NTP_CLOCK_CHANGE: System clock changed from 08:05:47:910 02/28/2023 to 08:05:48:894 02/28/2023, the NTP server's IP address is 210.34.0.10. %Feb 28 08:05:47:909 2023 SR8816-X NTP/5/NTP_SOURCE_CHANGE: NTP server's IP address changed from 210.34.0.11 to 210.34.0.10. %Feb 28 08:01:49:907 2023 SR8816-X NTP/4/NTP_SOURCE_LOST: Lost synchronization with NTP server with IP address 210.34.0.11. %Feb 28 07:35:28:852 2023 SR8816-X NTP/3/NTP_SERVER_ABNORMAL: NTP server state went abnormal. %Feb 28 07:35:25:902 2023 SR8816-X NTP/5/NTP_CLOCK_CHANGE: System clock changed from 07:35:25:995 02/28/2023 to 07:35:25:851 02/28/2023, the NTP server's IP address is 210.34.0.11. %Feb 28 07:25:19:967 2023 SR8816-X NTP/3/NTP_SERVER_ABNORMAL: NTP server state went abnormal.
设备时间和北京时间一致
粉丝:94人 关注:0人
ntp同步日志,如不需要可关闭ntp同步
之前没有发现,这是近期发现的,如果关闭了设备的时间会和北京时间不一致吗
zhiliao_SEF6fz 发表时间:2023-02-28
可以关闭试试
IT钟点工 发表时间:2023-02-28
NTP server state went abnormal. ntp server 日志显示状态异常。查看下ntp状态,dis ntp session或者status,然后检查下ntp配置。
