MSR3600+pppoe拨号无法触发拨号
2017-08-22提问
  • 1收藏,2963浏览
如下:interface Dialer10 11 12 13是客户之前配置的,后来又扩容新增两条pppoe链路,配置interface Dialer15 16但是配置完成之后debug查看根本就未触发pppoe拨号,联系二线也说配置无问题,后来第一天未解决,第二天晚上在配置 dialer timer idle 0命令立马pppoe拨号,测试把 dialer timer idle 5秒或者1秒都不触发拨号,很奇怪,前面4条pppoe链路也未配置此命令,这是我遇到的问题。
interface Dialer10
 mtu 1492
 ppp chap password cipher $c$3$kjKoR0lN5UUn+rQOKwXKNXtXr1apbuxB7g==
 ppp chap user 15349260880
 ppp ipcp dns admit-any
 ppp ipcp dns request
 ppp pap local-user 15349260880 password cipher $c$3$kjKoR0lN5UUn+rQOKwXKNXtXr1apbuxB7g==
 dialer bundle enable
 dialer-group 10
 ip address ppp-negotiate
 tcp mss 1024
 nat outbound 3100
interface Dialer11
 mtu 1492
 ppp chap password cipher $c$3$KeLPjVSiLgoCpTucxdEcEK7UTSk9mt8OQw==
 ppp chap user 02988862975
 ppp pap local-user 02988862975 password cipher $c$3$KeLPjVSiLgoCpTucxdEcEK7UTSk9mt8OQw==
 dialer-group 11
 tcp mss 1024
 nat outbound 3100
interface Dialer12
 mtu 1492
 ppp chap password cipher $c$3$TOBLo/PtFkdvOkeZRW/LhzNvwENf8asCxA==
 ppp chap user 02988862917
 ppp pap local-user 02988862917 password cipher $c$3$TOBLo/PtFkdvOkeZRW/LhzNvwENf8asCxA==
 dialer-group 12
 tcp mss 1024
 nat outbound 3100
interface Dialer13
 mtu 1492
 ppp chap password cipher $c$3$AbvXrTmknKFIbqLwXpzJHAPe6F1euNHEaA==
 ppp chap user 02986135162
 ppp pap local-user 02986135162 password cipher $c$3$ilg7EK3NYxQymaH6t8CPoeXcQxHIXTKuDA==
 dialer-group 13
 tcp mss 1024
 nat outbound 3100
interface Dialer15
 mtu 1492
 ppp pap local-user 02989821268 password cipher $c$3$50AH2D1AYdWSgvt6liURRf/lPnV1r7Srzg==
 dialer-group 15
 dialer timer idle 0
 tcp mss 1024
 nat outbound 3100
interface Dialer16
 mtu 1492
 ppp chap password cipher $c$3$tQftPlNrh2YgUurMSZDTH0OArDDNl3uN8g==
 ppp chap user 02989821208
 ppp pap local-user 02989821208 password cipher $c$3$FBnM/B3fk6QAMxJXBkV8Wv7SCq9jZ/18ug==
 dialer-group 16
 dialer timer idle 0
 tcp mss 1024
 nat outbound 3100
MSR配置6条PPPOE拨号,设备型号MSR V7平台
 dialer timer idle 0表示将自动触发拨号并永久在线,如果不为0,需要有流量才可以触发拨号,并且在配置的时间内如果没有流量经过,将自动挂断链路。
看是否有流量触发,解释同上
那我这么理解,如果不配置 dialer timer idle 0的话,我需要有流量经过这个接口去触发,才可以进行拨号,那我确实是没有流量触发,一开始就是想先配置好拨号测试内网上网,这样解释就能说通了,前面4条没有配置,但是有流量触发所以可以拨号成功。
