路由器
2023-02-28提问
  • 0收藏,823浏览
分支1的报错信息
debugging ipsec all
<R3>*Feb 28 16:11:36:721 2023 R3 IPSEC/7/EVENT: Can't find block-flow node. *Feb 28 16:11:36:722 2023 R3 IPSEC/7/PACKET: Failed to find SA by SP, SP Index = 0, SP Convert-Seq = 65536. *Feb 28 16:11:36:722 2023 R3 IPSEC/7/ERROR: The reason of dropping packet is no available IPsec tunnel. *Feb 28 16:11:36:722 2023 R3 IPSEC/7/EVENT: Sent SA-Acquire message : SP ID = 0 *Feb 28 16:11:36:722 2023 R3 IPSEC/7/EVENT: Received negotiatiate SA message from IPsec kernel. *Feb 28 16:11:36:722 2023 R3 IPSEC/7/EVENT: Got SA time-based soft lifetime settings when filling Sp data. Configured soft lifetime buffer : 0 seconds. Configured global soft lifetime buffer : 0 seconds. *Feb 28 16:11:36:723 2023 R3 IPSEC/7/EVENT: Sent delete SA message to all nodes, message type is 0x16. *Feb 28 16:11:36:723 2023 R3 IPSEC/7/EVENT: The SA doesn't exist in kernel. *Feb 28 16:11:36:723 2023 R3 IPSEC/7/EVENT: Remote address no need to change, SP index=0. <R3> <R3>*Feb 28 16:11:46:722 2023 R3 IPSEC/7/EVENT: Can't find block-flow node. *Feb 28 16:11:46:722 2023 R3 IPSEC/7/PACKET: Failed to find SA by SP, SP Index = 0, SP Convert-Seq = 65536. *Feb 28 16:11:46:722 2023 R3 IPSEC/7/ERROR: The reason of dropping packet is no available IPsec tunnel. *Feb 28 16:11:46:722 2023 R3 IPSEC/7/EVENT: Sent SA-Acquire message : SP ID = 0 *Feb 28 16:11:46:722 2023 R3 IPSEC/7/EVENT: Received negotiatiate SA message from IPsec kernel. *Feb 28 16:11:46:723 2023 R3 IPSEC/7/EVENT: Got SA time-based soft lifetime settings when filling Sp data. Configured soft lifetime buffer : 0 seconds. Configured global soft lifetime buffer : 0 seconds. *Feb 28 16:11:46:725 2023 R3 IPSEC/7/EVENT: Sent delete SA message to all nodes, message type is 0x16. *Feb 28 16:11:46:725 2023 R3 IPSEC/7/EVENT: The SA doesn't exist in kernel. *Feb 28 16:11:46:725 2023 R3 IPSEC/7/EVENT: Remote address no need to change, SP index=0. <R3>*Feb 28 16:11:56:722 2023 R3 IPSEC/7/EVENT: Can't find block-flow node. *Feb 28 16:11:56:722 2023 R3 IPSEC/7/PACKET: Failed to find SA by SP, SP Index = 0, SP Convert-Seq = 65536. *Feb 28 16:11:56:722 2023 R3 IPSEC/7/ERROR: The reason of dropping packet is no available IPsec tunnel. *Feb 28 16:11:56:722 2023 R3 IPSEC/7/EVENT: Sent SA-Acquire message : SP ID = 0 *Feb 28 16:11:56:722 2023 R3 IPSEC/7/EVENT: Received negotiatiate SA message from IPsec kernel. *Feb 28 16:11:56:722 2023 R3 IPSEC/7/EVENT: Got SA time-based soft lifetime settings when filling Sp data. Configured soft lifetime buffer : 0 seconds. Configured global soft lifetime buffer : 0 seconds. *Feb 28 16:11:56:724 2023 R3 IPSEC/7/EVENT: Sent delete SA message to all nodes, message type is 0x16. *Feb 28 16:11:56:724 2023 R3 IPSEC/7/EVENT: The SA doesn't exist in kernel. *Feb 28 16:11:56:724 2023 R3 IPSEC/7/EVENT: Remote address no need to change, SP index=0.
一总部两分支,总部侧固定ip   两分支pppoe拨号
粉丝:94人 关注:0人
1,ipsec没起来,检查两端ipsec 配置
