专线问题,比较复杂,实在找不到问题
  • 0收藏,688浏览
核心交换机访问子公司内网地址不通,子公司访问内网地址是通的,路由器4口子接口访问子公司内网地址也是通的,求助哪里出问题了,实在不知道哪里过滤了,需要修改哪里。
本地网段为:10.32.200.254(测试网段)
路由互联地址:10.34.1.41
路由器与子公司互联地址:10.248.33.125
下面是具体拓扑和交换机与路由器的路由表
公司新增一根联通专线,子公司出口地址位10.248.33.126,出口设备为防火墙。本地路由器4口做了子接口,G1/1/4.126,做的OSPF,地址为10.248.33.125,写了两条  静态路由访问子公司内网地址,1034.232-233.0两个网段的静态路由到10.248.33.126。
1口为核心交换机到路由互联口,4口下子接口.126为子接口与子公司互联。
核心交换机路由表:
ip route-static 0.0.0.0 0 10.34.1.190
 ip route-static 10.32.6.0 24 10.34.1.37
 ip route-static 10.32.14.0 24 10.34.1.37
 ip route-static 10.32.21.0 24 10.34.1.37
 ip route-static 10.32.28.0 24 10.34.1.37
 ip route-static 10.32.36.0 24 10.34.1.37
 ip route-static 10.32.37.0 24 10.32.34.62
 ip route-static 10.32.38.0 24 10.32.34.62
 ip route-static 10.32.39.0 24 100.100.88.232
 ip route-static 10.32.40.0 24 100.100.88.234
 ip route-static 10.32.41.0 24 100.100.88.234
 ip route-static 10.34.232.0 24 10.34.1.41
 ip route-static 10.34.233.0 24 10.34.1.41
 ip route-static 10.34.1.0 24 10.34.1.170
 ip route-static 10.34.1.176 29 10.34.1.169 preference 100
 ip route-static 10.34.1.184 29 10.34.1.169 preference 100
 ip route-static 192.168.200.0 24 10.34.1.182
 ip route-static 192.168.201.0 24 10.34.1.182
 ip route-static vpn-instance Guest 0.0.0.0 0 172.16.100.1
 ip route-static vpn-instance Guest 0.0.0.0 0 172.16.100.254 preference 100
 ssh server enable
 ssh user admin service-type stelnet authentication-type password
 ssh user hnys service-type stelnet authentication-type password
acl number 3000 name Anti-Virus
 rule 10 deny tcp destination-port eq 137
 rule 20 deny tcp destination-port eq 138
 rule 30 deny tcp destination-port eq 139
 rule 40 deny tcp destination-port eq 445
 rule 80 deny udp destination-port eq 445
 rule 90 permit ip
路由器路由表:
interface Tunnel1
 description g1/1/3_to_wukuang
 shutdown
 ip address 10.252.0.34 255.255.255.252
 tcp mss 1400
 source 10.252.0.62
 destination 10.252.0.57
bgp 65043
 router-id 10.244.32.2
 preference 9 8 200
 network 10.32.0.0 255.252.0.0
 network 10.244.32.0 255.255.252.0
 network 10.248.32.0 255.255.252.0
 undo synchronization
 peer 10.244.32.1 as-number 65043
 peer 10.252.0.57 as-number 65001
 peer 10.244.32.1 next-hop-local
 peer 10.244.32.1 connect-interface LoopBack0
 peer 10.252.0.57 ebgp-max-hop 2
ospf 1 router-id 10.244.32.2
 import-route static route-policy static2ospf
 import-route bgp cost 20 route-policy bgp2ospf
 silent-interface GigabitEthernet1/1/3
 area 0.0.0.0
  abr-summary 10.32.200.0 255.255.254.0
  network 10.34.1.40 0.0.0.3
  network 10.244.32.2 0.0.0.0
  network 10.34.1.76 0.0.0.3
  network 10.252.0.62 0.0.0.0
 area 0.0.0.2
  network 10.248.33.0 0.0.0.3
 area 0.0.0.3
  abr-summary 10.35.2.0 255.255.255.0
  network 10.248.33.4 0.0.0.3
 area 0.0.0.4
  network 10.248.33.8 0.0.0.3
 area 0.0.0.5
  network 10.248.33.12 0.0.0.3
 area 0.0.0.6
  network 10.248.33.16 0.0.0.3
 area 0.0.0.7
  network 10.248.33.20 0.0.0.3
 area 0.0.0.8
  network 10.248.33.24 0.0.0.3
 area 0.0.0.10
  network 10.248.33.32 0.0.0.3
 area 0.0.0.11
  network 10.248.33.36 0.0.0.3
 area 0.0.0.15
  network 10.248.33.40 0.0.0.3
 area 0.0.0.16
  network 10.248.33.128 0.0.0.3
 area 0.0.0.19
  network 10.248.33.69 0.0.0.0
 area 0.0.0.26
  network 10.248.33.125 0.0.0.0
 area 0.0.0.32
  network 10.248.33.28 0.0.0.3
route-policy bgp2ospf permit node 5
 if-match ip-prefix zigongyingzhi
route-policy bgp2ospf deny node 10
 if-match ip-prefix hunanyouse
route-policy bgp2ospf permit node 20
route-policy static2ospf permit node 10
 if-match ip-prefix static
 ip ip-prefix hunanyouse index 5 permit 10.32.0.0 14 less-equal 32
 ip ip-prefix hunanyouse index 10 permit 10.244.32.0 22 less-equal 32
 ip ip-prefix hunanyouse index 15 permit 10.248.32.0 22 less-equal 32
 ip ip-prefix jituan index 11 permit 10.1.0.0 16
 ip ip-prefix jituan index 12 permit 10.2.0.0 16
 ip ip-prefix jituan index 13 permit 10.255.1.0 24
 ip ip-prefix jituan index 14 permit 10.255.11.0 24
 ip ip-prefix jituan index 15 permit 10.248.0.0 24 less-equal 32
 ip ip-prefix youse index 10 permit 10.29.0.0 16 less-equal 32
 ip ip-prefix youse index 15 permit 10.40.0.0 16 less-equal 32
 ip ip-prefix youse index 20 permit 10.41.0.0 16 less-equal 32
 ip ip-prefix youse index 25 permit 10.42.0.0 16 less-equal 32
 ip ip-prefix static index 10 permit 10.252.0.56 30
 ip ip-prefix zigongyingzhi index 10 permit 10.34.96.0 19 less-equal 32
 ip ip-prefix zigongyingzhi index 20 permit 10.35.12.0 24 less-equal 32
 ip route-static 10.32.0.0 255.252.0.0 NULL0
 ip route-static 10.32.42.0 255.255.255.0 10.248.33.126
 ip route-static 10.32.43.0 255.255.255.0 10.248.33.126
 ip route-static 10.34.232.0 255.255.255.0 10.248.33.126
 ip route-static 10.34.233.0 255.255.255.0 10.248.33.126
 ip route-static 10.244.32.0 255.255.252.0 NULL0
 ip route-static 10.248.32.0 255.255.252.0 NULL0
 ip route-static 10.252.0.56 255.255.255.252 10.252.0.61
粉丝:119人 关注:1人
1、全局开启ttl 回显
2、带源tracert跟踪下路由
粉丝:15人 关注:0人
哥们 给个组网咋们还可以梳理一下
组网太复杂了,就是单纯看核心交换机到路由器,然后路由器4口出去到子公司内网
zhiliao_2nfIRa 发表时间:2023-03-03
zhiliao_2nfIRa 知了小白
  这是大概拓扑
