uc纳管设备以后无法通过uc界面telnet到设备
2023-03-06提问
  • 0收藏,625浏览
设备telnet已配置,在uc可以ping通设备。通过uc的web可以ssh登录到设备,无法出现telnet界面,是什么原因导致的?
粉丝:119人 关注:1人
看下报错日志
%Jan 4 20:10:00:830 2013 UC CFGMAN/5/CFGMAN_CFGCHANGED: -EventIndex=87-CommandSource=snmp-COnfigSource=startup-COnfigDestination=running; Configuration changed. %Jan 4 20:00:50:161 2013 UC SNMP/6/SNMP_SET: -seqNO=42-srcIP=210.34.0.91-op=SET-errorIndex=0-errorStatus=noError-node=sysName(1.3.6.1.2.1.1.5.0)-value=UC; The agent received a message. %Jan 4 18:10:00:830 2013 UC CFGMAN/5/CFGMAN_CFGCHANGED: -EventIndex=85-CommandSource=snmp-COnfigSource=startup-COnfigDestination=running; Configuration changed. %Jan 4 18:00:39:667 2013 UC SNMP/6/SNMP_SET: -seqNO=41-srcIP=210.34.0.91-op=SET-errorIndex=0-errorStatus=noError-node=sysName(1.3.6.1.2.1.1.5.0)-value=UC; The agent received a message. %Jan 4 16:10:00:830 2013 UC CFGMAN/5/CFGMAN_CFGCHANGED: -EventIndex=83-CommandSource=snmp-COnfigSource=startup-COnfigDestination=running; Configuration changed. %Jan 4 16:00:29:013 2013 UC SNMP/6/SNMP_SET: -seqNO=40-srcIP=210.34.0.91-op=SET-errorIndex=0-errorStatus=noError-node=sysName(1.3.6.1.2.1.1.5.0)-value=UC; The agent received a message. 这些信息
zhiliao_SEF6fz 发表时间:2023-03-06
这个是snmp的日志,看看你telnet登录报错的日志,ucneter上的
叫我靓仔 发表时间:2023-03-06
回复叫我靓仔:
uc上面没有任何关于telnet 的日志
