8812作为ntp 服务器同步下联PE 时钟,检测到漏洞NTP Mode 6,需限制ntp mod-6查询
(0)
A:关于NTP MODE 6字段的报文攻击:
CVE-2016-9310:
An exploitable configuration modification vulnerability exists in the control mode (mode 6) functionality of ntpd. If, against long-standing BCP recommendations, "restrict default noquery ..." is not specified, a specially crafted control mode packet can set ntpd traps, providing information disclosure and DDoS amplification, and unset ntpd traps, disabling legitimate monitoring. A remote, unauthenticated, network attacker can trigger this vulnerability.
Ntp对于mode 6的写命令(如set trap和write clock status)没有进行认证保护,导致攻击者能通过该命令反复操作ntp。
V7和V5均不支持通过mode6报文对ntp进行写操作,因此无此问题。
(0)
也就是虽然被扫出来了,但是不用去在意这个。
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
如果是服务端呢?
