集中转发下,终端数据上传到AC,在通过capwap隧道时,终端数据使用什么加密方式?
2023-03-13提问
  • 0收藏,502浏览
集中转发下,数据上传到AC,在通过capwap隧道时,使用什么加密方式?
注:这个加密的报文不是加密控制报文,是加密终端的数据报文。
筱坏 七段
粉丝:7人 关注:0人
仅仅是走capwap隧道,没有安全加密
粉丝:148人 关注:1人
1.      开启CAPWAP控制隧道加密命令:
tunnel encryption enable命令用来开启CAPWAP控制隧道加密功能。
tunnel encryption disable命令用来关闭CAPWAP控制隧道加密功能。
undo tunnel encryption enable命令用来恢复缺省情况。
tunnel encryption { disable | enable }
AP视图:继承AP组配置。
AP组视图:CAPWAP控制隧道加密功能处于关闭状态。
2、开启CAPWAP数据隧道加密命令:
encryption enable命令用来开启CAPWAP数据隧道加密功能。
encryption disable命令用来关闭CAPWAP数据隧道加密功能。
undo encryption命令用来恢复缺省情况。
undo encryption
AP视图:继承AP组配置。
AP组视图:CAPWAP数据隧道加密功能处于关闭状态。
3、ACAP设备会默认打包证书,即可以使用默认证书进行加密  (配上隧道加密命令后会自动调用系统证书,无需额外配置
解决方法
配置加密后,AP会重新上下线:
 [H3C-wlan-ap-d461-fe9c-xxxx]tunnel encryption enable  //开启CAPWAP控制隧道加密功能。
This operation will reconnect the AP. Continue? [Y/N]y
%Mar 29 16:21:48:381 2021 H3C CWS/4/CWS_AP_DOWN: CAPWAP tunnel to AP d461-fe9c-xxxx went down. Reason: Encryption status mismatch.
%Mar 29 16:21:48:383 2021 H3C APMGR/6/APMGR_AP_OFFLI NE: AP d461-fe9c-xxxx went offline. State changed to Idle.
%Mar 29 16:21:54:920 2021 H3C APMGR/6/AP MGR_AP_ONLINE: AP d461-fe9c-xxxx came online. State changed to Run.
%Mar 29 16:21:54:920 2021 H3C CWS/6/CWS_AP_UP: Master CAPWAP tunnel to AP d461-f e9c-xxxx went up
[H3C-wlan-ap-d461-fe9c-f6e0]>CAPWAP数据隧道加密功能。
%Mar 29 16:22:13:317 2021 H3C CWS/4/CWS_AP_DOWN: CAP WAP tunnel to AP d461-fe9c-xxxx went down. Reason: Encryption status mismatch.
%Mar 29 16:22:13:319 2021 H3C APMGR/6/APMGR_AP_OFFLINE: AP d461-fe9c-xxxx went o ffline. State changed to Idle
%Mar 29 16:22:17:078 2021 H3C APMGR/6/APMGR_AP_ONLIN E: AP d461-fe9c-xxxx came online. State changed to Run
 %Mar 29 16:22:17:078 2021 H3C CWS/6/CWS_AP_UP: Master CAPWAP tunnel to AP d461-f e9c-xxxx went up
