AC控制IP地址偶尔ping不同,无线网络无法正常使用
2023-03-18提问
  • 0收藏,928浏览
AC控制IP地址偶尔ping不同,无线网络无法正常使用,AC上有大量异常告警,不知道什么意思:
.Ap:TSL.MidName:MID_ETH_PORT_1.EvtType:Port rx error pkt continuously increase.WarningNum:82.Action:Generate.Level:Attention
%Mar 18 10:02:41:152 2023 H3c_AC STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 365a-bcfc-723c went offline from BSS 5098-b8c5-6ed0 with SSID GHZGE on AP ST04 Radio ID 2. State changed to Unauth. Reason: Received deauthentication frame in Run state: reason code=3 %Mar 18 10:02:42:551 2023 H3c_AC STAMGR/6/STAMGR_CLIENT_ONLINE: Client 365a-bcfc-723c went online from BSS 5098-b8c5-6ed0 vlan 32 with SSID GHZGE on AP ST04 Radio ID 2. State changed to Run. %Mar 18 10:02:52:051 2023 H3c_AC APMGR/6/APMGR_LOG_ALARM: Time:2023-03-18T10:02:24.099Z.Ap:TSC_mesh.MidName:MID_ETH_PORT_1.EvtType:Port status change to down.WarningNum:49.Action:Recover.Level:Critical. %Mar 18 10:02:52:054 2023 H3c_AC APMGR/6/APMGR_LOG_ALARM: Time:2023-03-18T10:02:30.115Z.Ap:TSC_mesh.MidName:MID_ETH_PORT_1.EvtType:Port status change to down.WarningNum:50.Action:Generate.Level:Critical. %Mar 18 10:02:52:054 2023 H3c_AC APMGR/6/APMGR_LOG_ALARM: Time:2023-03-18T10:02:39.139Z.Ap:TSC_mesh.MidName:MID_ETH_PORT_1.EvtType:Port status change to down.WarningNum:50.Action:Recover.Level:Critical. %Mar 18 10:02:52:055 2023 H3c_AC APMGR/6/APMGR_LOG_ALARM: Time:2023-03-18T10:02:48.163Z.Ap:TSC_mesh.MidName:MID_ETH_PORT_1.EvtType:Port status change to down.WarningNum:51.Action:Generate.Level:Critical. %Mar 18 10:02:52:055 2023 H3c_AC APMGR/6/APMGR_LOG_ALARM: Time:2023-03-18T10:02:06.051Z.Ap:TSC_mesh.MidName:MID_ETH_PORT_1.EvtType:Port status change to down.WarningNum:48.Action:Recover.Level:Critical. %Mar 18 10:02:52:055 2023 H3c_AC APMGR/6/APMGR_LOG_ALARM: Time:2023-03-18T10:02:12.067Z.Ap:TSC_mesh.MidName:MID_ETH_PORT_1.EvtType:Port status change to down.WarningNum:49.Action:Generate.Level:Critical. %Mar 18 10:03:00:624 2023 H3c_AC STAMGR/6/STAMGR_CLIENT_OFFLINE: Client 365a-bcfc-723c went offline from BSS 5098-b8c5-6ed0 with SSID GHZGE on AP ST04 Radio ID 2. State changed to Unauth. Reason: Received deauthentication frame in Run state: reason code=3 %Mar 18 10:03:01:931 2023 H3c_AC STAMGR/6/STAMGR_CLIENT_ONLINE: Client 365a-bcfc-723c went online from BSS 5098-b8c5-6ed0 vlan 32 with SSID GHZGE on AP ST04 Radio ID 2. State changed to Run.
粉丝:4人 关注:0人
可以联系下无线工程师看下
粉丝:119人 关注:1人
1、发现很多接口down的日志,你看下是不是接口不稳定,可以考虑换一根网线试试:Port status change to down
2、最简单的办法,直接用标杆的神器,一键巡检,发现问题
3、另外也可以注册到云简,一键分析
4、人工分析需要查看很多参数,比如接口协商速率、stp状态、设备负载等
