交换机死机
2023-03-22提问
  • 0收藏,939浏览
<H3C>display logbuffer
 Log buffer: Enabled
Max buffer size: 1024
Actual buffer size: 512
 Dropped messages: 0
Overwritten messages: 0
Current messages: 8
%Dec 31 23:59:33:227 2012 H3C SYSLOG/6/SYSLOG_RESTART: System restarted --
H3C Comware Software.
%Jan 1 00:00:36:489 2013 H3C SHELL/6/SHELL_CMDFAIL: The interface Ten-GigabitEthernet 1/0/5 command fails to restore configuration. %Jan 1 00:00:36:499 2013 H3C SHELL/6/SHELL_CMDFAIL: The interface Ten-GigabitEthernet 1/0/6 command fails to restore configuration. %Jan 1 00:00:36:703 2013 H3C STP/6/STP_ENABLE: STP is now enabled on the device. %Jan 1 00:00:37:274 2013 H3C SHELL/6/SHELL_CMDFAIL: The interface Ten-GigabitEthernet 1/0/5 command fails to restore configuration. %Jan 1 00:00:37:285 2013 H3C SHELL/6/SHELL_CMDFAIL: The interface Ten-GigabitEthernet 1/0/6 command fails to restore configuration. %Jan 1 00:00:37:322 2013 H3C SHELL/4/SHELL_CMD_MATCHFAIL: -User=-IPAddr=; Command undo access-limit enable in view isp-system failed to be matched. %Jan 1 00:04:05:773 2013 H3C SHELL/5/SHELL_LOGIN: TTY logged in from aux0.
交换机死机  重启打开之后查日志是这样的有什么问题吗
Menxin 四段
SHELL/6/SHELL_CMDFAIL:文本配置恢复操作失败
SHELL/4/SHELL_CMD_MATCHFAIL: 由于命令输入错误,或者当前模式错误等,造成命令匹配错误
死机,是指自动重启吗,dis version看下last reboot reason
建议收集下诊断信息和logfile,联系二线协助看下。
粉丝:127人 关注:8人
这是重启后的一些 日志,太乱了。。
