MSR3600-51-SI版本r6728p25缺少命令pppoe-server
2023-03-23提问
  • 0收藏,648浏览
- 系统版本如下
[MSR3600-8xiang-2]dis version
H3C Comware Software, Version 7.1.064, Release 6728P25
Copyright (c) 2004-2022 New H3C Technologies Co., Ltd. All rights reserved.
H3C MSR3600 uptime is 0 weeks, 0 days, 0 hours, 30 minutes
Last reboot reason : User reboot
Boot image: flash:/msr3600si-cmw710-boot-r6728p25.bin
Boot image version: 7.1.064P80, Release 6728P25
Compiled Nov 23 2022 15:00:00
System image: flash:/msr3600si-cmw710-system-r6728p25.bin
System image version: 7.1.064, Release 6728P25
Feature image(s) list:
flash:/msr3600si-cmw710-security-r6728p25.bin, version: 7.1.064
flash:/msr3600si-cmw710-voice-r6728p25.bin, version: 7.1.064
flash:/msr3600si-cmw710-data-r6728p25.bin, version: 7.1.064
- 缺少 pppoe-client
[MSR3600-8xiang-2]interface GigabitEthernet0/0
[MSR3600-8xiang-2-GigabitEthernet0/0]pppoe-client ?
% Unrecognized command found at '^' position.
- 缺少 pppoe-server 命令
[MSR3600-8xiang-2]interface Vlan-interface2
[MSR3600-8xiang-2-Vlan-interface2]pppoe-server ?
xixi 四段
看了一下手册,pppoe-client是可以支持的
01-PPP命令-新华三集团-H3C
pppoe-server后面可以跟很多参数,您看您想配什么,上面链接里面都有的,是根据设备当前版本找的手册,可以参考下
[MSR3600-8xiang-2]display pppoe-? ^ % Unrecognized command found at '^' position. 直接用 display pppoe-? 也提示没有可用命令, 太奇怪了
lynatgz 发表时间:2023-03-24
键盘上tab键应该可以补全吧,可以试一下
xixi 发表时间:2023-03-24
回复xixi :
不行才来问的,我其他旧款msr2600都可以
lynatgz 知了小白
% Unrecognized command found at "^" position.
