ER3260G3经常上不了外网
2023-03-25提问
  • 0收藏,453浏览
不间断会出现。外网上不了,内网正常。重启也没用。
4 个回答
粉丝:6人 关注:1人
电脑直接接外网可以测试吗?如果没问题的话电脑接在路由器上看下是否正常,如果不正常可以升级下路由器的版本,还是不行的话只能联系400问下了
ri Jan 1 00:00:32 2010 ***.*** dhcpd: Wrote 0 class decls to leases file. Fri Jan 1 00:00:32 2010 ***.*** rc.common: app_name:nat_app , kmod_name:ipt_TRIGGER , insert ok Fri Jan 1 00:00:32 2010 ***.*** dhcpd: Wrote 0 leases to leases file. Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: No subnet declaration for wan1.1 (no IPv4 addresses). Fri Jan 1 00:00:32 2010 daemon.err dhcpd: ** Ignoring requests on wan1.1. If this is not what Fri Jan 1 00:00:32 2010 daemon.err dhcpd: you want, please write a subnet declaration Fri Jan 1 00:00:32 2010 daemon.err dhcpd: in your dhcpd.conf file for the network segment Fri Jan 1 00:00:32 2010 daemon.err dhcpd: to which interface wan1.1 is attached. ** Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: No subnet declaration for wan5-lan2.1 (no IPv4 addresses). Fri Jan 1 00:00:32 2010 daemon.err dhcpd: ** Ignoring requests on wan5-lan2.1. If this is not what Fri Jan 1 00:00:32 2010 daemon.err dhcpd: you want, please write a subnet declaration Fri Jan 1 00:00:32 2010 daemon.err dhcpd: in your dhcpd.conf file for the network segment Fri Jan 1 00:00:32 2010 daemon.err dhcpd: to which interface wan5-lan2.1 is attached. ** Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: No subnet declaration for wan4-lan3.1 (no IPv4 addresses). Fri Jan 1 00:00:32 2010 daemon.err dhcpd: ** Ignoring requests on wan4-lan3.1. If this is not what Fri Jan 1 00:00:32 2010 daemon.err dhcpd: you want, please write a subnet declaration Fri Jan 1 00:00:32 2010 daemon.err dhcpd: in your dhcpd.conf file for the network segment Fri Jan 1 00:00:32 2010 daemon.err dhcpd: to which interface wan4-lan3.1 is attached. ** Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: No subnet declaration for wan3-lan4.1 (no IPv4 addresses). Fri Jan 1 00:00:32 2010 daemon.err dhcpd: ** Ignoring requests on wan3-lan4.1. If this is not what Fri Jan 1 00:00:32 2010 daemon.err dhcpd: you want, please write a subnet declaration Fri Jan 1 00:00:32 2010 daemon.err dhcpd: in your dhcpd.conf file for the network segment Fri Jan 1 00:00:32 2010 daemon.err dhcpd: to which interface wan3-lan4.1 is attached. ** Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: No subnet declaration for wan2-lan5.1 (no IPv4 addresses). Fri Jan 1 00:00:32 2010 daemon.err dhcpd: ** Ignoring requests on wan2-lan5.1. If this is not what Fri Jan 1 00:00:32 2010 daemon.err dhcpd: you want, please write a subnet declaration Fri Jan 1 00:00:32 2010 daemon.err dhcpd: in your dhcpd.conf file for the network segment Fri Jan 1 00:00:32 2010 daemon.err dhcpd: to which interface wan2-lan5.1 is attached. ** Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: No subnet declaration for lan1.1 (no IPv4 addresses). Fri Jan 1 00:00:32 2010 daemon.err dhcpd: ** Ignoring requests on lan1.1. If this is not what Fri Jan 1 00:00:32 2010 daemon.err dhcpd: you want, please write a subnet declaration Fri Jan 1 00:00:32 2010 daemon.err dhcpd: in your dhcpd.conf file for the network segment Fri Jan 1 00:00:32 2010 daemon.err dhcpd: to which interface lan1.1 is attached. ** Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: No subnet declaration for lan1 (no IPv4 addresses). Fri Jan 1 00:00:32 2010 daemon.err dhcpd: ** Ignoring requests on lan1. If this is not what Fri Jan 1 00:00:32 2010 daemon.err dhcpd: you want, please write a subnet declaration Fri Jan 1 00:00:32 2010 daemon.err dhcpd: in your dhcpd.conf file for the network segment Fri Jan 1 00:00:32 2010 daemon.err dhcpd: to which interface lan1 is attached. ** Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: No subnet declaration for wan5-lan2 (no IPv4 addresses). Fri Jan 1 00:00:32 2010 daemon.err dhcpd: ** Ignoring requests on wan5-lan2. If this is not what Fri Jan 1 00:00:32 2010 daemon.err dhcpd: you want, please write a subnet declaration Fri Jan 1 00:00:32 2010 daemon.err dhcpd: in your dhcpd.conf file for the network segment Fri Jan 1 00:00:32 2010 daemon.err dhcpd: to which interface wan5-lan2 is attached. ** Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: No subnet declaration for wan4-lan3 (no IPv4 addresses). Fri Jan 1 00:00:32 2010 daemon.err dhcpd: ** Ignoring requests on wan4-lan3. If this is not what Fri Jan 1 00:00:32 2010 daemon.err dhcpd: you want, please write a subnet declaration Fri Jan 1 00:00:32 2010 daemon.err dhcpd: in your dhcpd.conf file for the network segment Fri Jan 1 00:00:32 2010 daemon.err dhcpd: to which interface wan4-lan3 is attached. ** Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: No subnet declaration for wan3-lan4 (no IPv4 addresses). Fri Jan 1 00:00:32 2010 daemon.err dhcpd: ** Ignoring requests on wan3-lan4. If this is not what Fri Jan 1 00:00:32 2010 daemon.err dhcpd: you want, please write a subnet declaration Fri Jan 1 00:00:32 2010 daemon.err dhcpd: in your dhcpd.conf file for the network segment Fri Jan 1 00:00:32 2010 daemon.err dhcpd: to which interface wan3-lan4 is attached. ** Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: No subnet declaration for wan2-lan5 (no IPv4 addresses). Fri Jan 1 00:00:32 2010 daemon.err dhcpd: ** Ignoring requests on wan2-lan5. If this is not what Fri Jan 1 00:00:32 2010 daemon.err dhcpd: you want, please write a subnet declaration Fri Jan 1 00:00:32 2010 daemon.err dhcpd: in your dhcpd.conf file for the network segment Fri Jan 1 00:00:32 2010 daemon.err dhcpd: to which interface wan2-lan5 is attached. ** Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: No subnet declaration for wan1 (no IPv4 addresses). Fri Jan 1 00:00:32 2010 daemon.err dhcpd: ** Ignoring requests on wan1. If this is not what Fri Jan 1 00:00:32 2010 daemon.err dhcpd: you want, please write a subnet declaration Fri Jan 1 00:00:32 2010 daemon.err dhcpd: in your dhcpd.conf file for the network segment Fri Jan 1 00:00:32 2010 daemon.err dhcpd: to which interface wan1 is attached. ** Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 daemon.err dhcpd: No subnet declaration for eth0 (no IPv4 addresses). Fri Jan 1 00:00:32 2010 daemon.err dhcpd: ** Ignoring requests on eth0. If this is not what Fri Jan 1 00:00:32 2010 daemon.err dhcpd: you want, please write a subnet declaration Fri Jan 1 00:00:32 2010 daemon.err dhcpd: in your dhcpd.conf file for the network segment Fri Jan 1 00:00:32 2010 daemon.err dhcpd: to which interface eth0 is attached. ** Fri Jan 1 00:00:32 2010 daemon.err dhcpd: Fri Jan 1 00:00:32 2010 ***.*** rc.common: app_name:nat_app , kmod_name:nfnetlink , insert ok Fri Jan 1 00:00:32 2010 ***.*** dhcpd: Server starting service. Fri Jan 1 00:00:32 2010 ***.*** rc.common: app_name:nat_app , kmod_name:nf_conntrack_netlink , insert ok Fri Jan 1 00:00:32 2010 user.notice ddns.hotplug: ifup, Vlan1, br-Vlan1, Fri Jan 1 00:00:32 2010 ***.*** rc.common: app_name:nat_app , kmod_name:ipt_VSERVER , insert ok Fri Jan 1 00:00:32 2010 ***.*** rc.common: app_name:nat_app , kmod_name:xt_multiport , insert ok Fri Jan 1 00:00:32 2010 ***.*** rc.common: app_name:nat_app , kmod_name:xt_comment , insert ok Fri Jan 1 00:00:32 2010 ***.*** rc.common: app_name:nat_app , kmod_name:iptable_mangle , insert ok Fri Jan 1 00:00:32 2010 user.notice 96-ipsec: ifup Vlan1 br-Vlan1 Fri Jan 1 00:00:32 2010 user.notice [event]netstate: fini: ifup-Vlan1 Fri Jan 1 00:00:32 2010 ***.*** dhcpd: DHCPDISCOVER from 90:23:b4:d6:00:fb via br-Vlan1 Fri Jan 1 00:00:32 2010 user.notice [event]netstate: init: ifup-wan1 Fri Jan 1 00:00:33 2010 local7.notice net-snmp[8879]: registered debug token trap, 1 Fri Jan 1 00:00:33 2010 local7.debug net-snmp[8879]: trap: Fri Jan 1 00:00:33 2010 local7.debug net-snmp[8879]: handling I Fri Jan 1 00:00:33 2010 local7.debug net-snmp[8879]: trap: Fri Jan 1 00:00:33 2010 local7.debug net-snmp[8879]: snmptrap_mv2 disabled Fri Jan 1 00:00:33 2010 user.notice [event]route: Setup default route and DNS route Fri Jan 1 00:00:33 2010 user.notice [event]route: Setup default route: ip route replace table default default proto static nexthop dev pppoe-wan1 via 100.64.0.1 Fri Jan 1 00:00:33 2010 ***.*** kernel: [ 41.269510] dsa dsa@0 wan4-lan3: get copper link! Fri Jan 1 00:00:33 2010 ***.*** kernel: [ 41.288663] dsa dsa@0 wan4-lan3: Link is Up - 1Gbps/Full - flow control off Fri Jan 1 00:00:33 2010 kern.notice kernel: [ 41.296658] syslogsource1:syslogpattern%s %s Link is Up - %s/%s:syslogformatlan3,Copper,1Gbps,Full, Fri Jan 1 00:00:33 2010 ***.*** kernel: [ 41.322046] IPv6: ADDRCONF(NETDEV_CHANGE): wan4-lan3: link becomes ready Fri Jan 1 00:00:33 2010 daemon.notice netifd: Network device 'wan4-lan3' link is up Fri Jan 1 00:00:33 2010 ***.*** kernel: [ 41.331659] br-Vlan1: port 4(wan4-lan3.1) entered blocking state Fri Jan 1 00:00:33 2010 ***.*** kernel: [ 41.337971] br-Vlan1: port 4(wan4-lan3.1) entered forwarding state Fri Jan 1 00:00:33 2010 daemon.notice netifd: VLAN 'wan4-lan3.1' link is up Fri Jan 1 00:00:33 2010 user.notice [event]route: Setup dns route: ip route replace table 250 202.96.134.133 proto static metric 2 nexthop dev pppoe-wan1 via 100.64.0.1 Fri Jan 1 00:00:33 2010 user.notice [event]route: Setup dns route: ip route replace table 250 202.96.128.166 proto static metric 2 nexthop dev pppoe-wan1 via 100.64.0.1 Fri Jan 1 00:00:33 2010 ***.*** dhcpd: DHCPOFFER on 172.17.1.3 to 90:23:b4:d6:00:fb (H3C) via br-Vlan1 Fri Jan 1 00:00:34 2010 user.err Adapter.NAT.NATALGConfig: Method function run failed Sat Mar 25 09:22:53 2023 user.notice [event]mwan3: : ifup-wan1 Sat Mar 25 09:22:53 2023 ***.*** crond[9396]: crond (busybox 1.25.1) started, log level 5 Sat Mar 25 09:22:53 2023 ***.*** crond[9432]: crond (busybox 1.25.1) started, log level 5 Sat Mar 25 09:22:53 2023 user.notice SYSTEM: syslogsource1:syslogpatternDate:%s NTP server sync succeed!:syslogformatSat Mar 25 09:22:53 GMT-8 2023 Sat Mar 25 09:22:53 2023 ***.*** kernel: [ 43.682115] l2tp_core: L2TP core driver, V2.0 Sat Mar 25 09:22:53 2023 ***.*** kernel: [ 43.689823] l2tp_netlink: L2TP netlink interface Sat Mar 25 09:22:53 2023 ***.*** kernel: [ 43.713652] l2tp_ppp: PPPoL2TP kernel driver, V2.0 Sat Mar 25 09:22:53 2023 ***.*** dhcpd: DHCPDISCOVER from 90:23:b4:d6:00:74 via br-Vlan1 Sat Mar 25 09:22:53 2023 user.notice : Service.KmodManager app_name:xl2tpd_server kmod_name:l2tp_ppp insert succeed Sat Mar 25 09:22:53 2023 user.notice : Service.KmodManager app_name:xl2tpd_server kmod_name:l2tp_netlink insert succeed Sat Mar 25 09:22:53 2023 user.notice : Service.KmodManager app_name:xl2tpd_server kmod_name:l2tp_core insert succeed Sat Mar 25 09:22:53 2023 user.notice : Service.KmodManager app_name:xl2tpd_server kmod_name:udp_tunnel insert succeed Sat Mar 25 09:22:54 2023 daemon.crit xl2tpd[9593]: setsockopt recvref[30]: Protocol not available Sat Mar 25 09:22:54 2023 ***.*** xl2tpd[9593]: Using l2tp kernel support. Sat Mar 25 09:22:54 2023 ***.*** xl2tpd[9593]: xl2tpd version xl2tpd-1.3.6 started on H3C PID:9593 Sat Mar 25 09:22:54 2023 ***.*** xl2tpd[9593]: Written by Mark Spencer, Copyright (C) 1998, Adtran, Inc. Sat Mar 25 09:22:54 2023 ***.*** xl2tpd[9593]: Forked by Scott Balmos and David Stipp, (C) 2001 Sat Mar 25 09:22:54 2023 ***.*** xl2tpd[9593]: Inherited by Jeff McAdams, (C) 2002 Sat Mar 25 09:22:54 2023 ***.*** xl2tpd[9593]: Forked again by Xelerance (***.***) (C) 2006 Sat Mar 25 09:22:54 2023 ***.*** xl2tpd[9593]: Listening on IP address 0.0.0.0, port 1701 Sat Mar 25 09:22:54 2023 user.notice Adapter_LastHop: Adapter.Network.LastHopHold enabled Sat Mar 25 09:22:54 2023 user.notice : Service.KmodManager app_name:Adapter.Network.LastHopHold kmod_name:xt_comment insert succeed Sat Mar 25 09:22:54 2023 ***.*** [initialization]: The counter of link up wan interface is 1, multiwan policy is not necessary Sat Mar 25 09:22:54 2023 user.notice : Service.KmodManager app_name:Adapter.Network.LastHopHold kmod_name:xt_mark insert succeed Sat Mar 25 09:22:54 2023 user.notice : Service.KmodManager app_name:Adapter.Network.LastHopHold kmod_name:xt_connmark insert succeed Sat Mar 25 09:22:54 2023 user.notice : Service.KmodManager app_name:Adapter.Network.LastHopHold kmod_name:nf_conntrack_ipv4 insert succeed Sat Mar 25 09:22:54 2023 user.notice qos: ifup interface wan1 (pppoe-wan1) Sat Mar 25 09:22:54 2023 user.notice : Service.KmodManager app_name:Adapter.Network.LastHopHold kmod_name:nf_conntrack insert succeed Sat Mar 25 09:22:54 2023 ***.*** dhcpd: DHCPDISCOVER from 90:23:b4:d6:00:fb (H3C) via br-Vlan1 Sat Mar 25 09:22:54 2023 user.notice : Service.KmodManager app_name:Adapter.Network.LastHopHold kmod_name:iptable_mangle insert succeed Sat Mar 25 09:22:54 2023 user.notice : Service.KmodManager app_name:qos kmod_name:xt_CLASSIFY insert succeed Sat Mar 25 09:22:54 2023 ***.*** dhcpd: DHCPOFFER on 172.17.1.2 to 90:23:b4:d6:00:74 (H3C) via br-Vlan1 Sat Mar 25 09:22:54 2023 ***.*** dhcpd: Wrote 0 class decls to leases file. Sat Mar 25 09:22:54 2023 ***.*** dhcpd: Wrote 2 leases to leases file. Sat Mar 25 09:22:54 2023 ***.*** dhcpd: DHCPREQUEST for 172.17.1.2 (192.168.2.1) from 90:23:b4:d6:00:74 (H3C) via br-Vlan1 Sat Mar 25 09:22:54 2023 ***.*** dhcpd: DHCPACK on 172.17.1.2 to 90:23:b4:d6:00:74 (H3C) via br-Vlan1
zhiliao_h4Y4fb 发表时间:2023-03-25
看看能看到异常不,一周好像都出现一次。去问了电信那边说他们正常
zhiliao_h4Y4fb 知了小白
都是最新版本了,之前反馈过好几次,最后突然就好了。
zhiliao_h4Y4fb 知了小白
之前拔下路由到宽带路由的网线就正常,现在好像也不行了
zhiliao_h4Y4fb 知了小白
等连上完,我发下日志你们看看?
