inode获取SSLVPN 网络参数失败
2023-03-25提问
  • 0收藏,657浏览
[2023-03-25 21:43:41] [Dbg] [55cc] VpnWidget::HandleProcessMsg :ConnId is 7001 processName:检查本地网络环境... stepErrInfo: [2023-03-25 21:43:41] [Dbg] [55cc] BaseWidget::HandleConTime :ConnId is 7001 conntime:2023-3-25 21:43:41 [2023-03-25 21:43:41] [Dbg] [55cc] BaseWidget::HandleLog :ConnId is 7001 正在清除以前配置的VPN网络环境... [2023-03-25 21:43:41] [Dbg] [55cc] BaseWidget::HandleLog :ConnId is 7001 本地网络环境检查通过。 [2023-03-25 21:43:41] [Dbg] [55cc] VpnWidget::HandleProcessMsg :ConnId is 7001 processName:检查本地网络环境... stepErrInfo: [2023-03-25 21:43:41] [Dbg] [55cc] VpnWidget::HandleProcessMsg :ConnId is 7001 processName:正在身份认证... stepErrInfo: [2023-03-25 21:43:41] [Dbg] [55cc] BaseWidget::HandleLog :ConnId is 7001 开始进行身份验证... [2023-03-25 21:43:41] [Dbg] [55cc] BaseWidget::HandleLog :ConnId is 7001 发送认证请求消息... [2023-03-25 21:43:43] [Dbg] [5574] BaseWidget::HandleLog :ConnId is 7001 身份验证成功。 [2023-03-25 21:43:43] [Dbg] [5574] VpnWidget::HandleProcessMsg :ConnId is 7001 processName:正在身份认证... stepErrInfo: [2023-03-25 21:43:43] [Dbg] [5574] VpnWidget::HandleProcessMsg :ConnId is 7001 processName:建立VPN隧道... stepErrInfo: [2023-03-25 21:43:43] [Dbg] [5574] BaseWidget::HandleLog :ConnId is 7001 开始建立VPN隧道... [2023-03-25 21:43:43] [Dbg] [55d0] BaseWidget::HandleLog :ConnId is 7001 关闭SSL VPN虚拟网卡。 [2023-03-25 21:43:43] [Dbg] [5590] BaseWidget::HandleLog :ConnId is 7001 从远程SSL VPN网关获取IP地址... [2023-03-25 21:43:43] [Dbg] [55cc] BaseWidget::HandleLog :ConnId is 7001 建立VPN隧道失败。 [2023-03-25 21:43:43] [Dbg] [55cc] VpnWidget::HandleProcessMsg :ConnId is 7001 processName:建立VPN隧道... stepErrInfo:获取SSL VPN网络参数失败。 [2023-03-25 21:43:43] [Dbg] [55ec] BaseWidget::showITDoorProgramsBtn :Begin. [2023-03-25 21:43:43] [Dbg] [55ec] BaseWidget::showITDoorProgramsBtn :m_ConID is not found. [2023-03-25 21:43:43] [DtlCmn] [55d0] VpnWidget::HandleLog the content is null. [2023-03-25 21:43:43] [Fatal] [55d0] BaseWidget::HandleLog the content is null. [2023-03-25 21:43:43] [Dbg] [55ec] BaseWidget::showITDoorProgramsBtn :Begin. [2023-03-25 21:43:43] [Dbg] [55ec] BaseWidget::showITDoorProgramsBtn :m_ConID is not found.
粉丝:171人 关注:8人
有认证成功的记录,建议结合VPN设备排查
参考:
SSLVPN功能故障排查
粉丝:3人 关注:0人
您好:看您的日志信息已经导拿地址的阶段了,
1.可以确认下vpn设备是否配置变更?
2.更新一下inode版本
3.可以在vpn设备上debug看一下
*Mar 25 23:28:55:406 2023 H3C SVPN/7/IPAC_EVENT: Succeeded in creating an ACL list. *Mar 25 23:28:55:406 2023 H3C SVPN/7/IPAC_ERROR: Failed to create a new connection. debug提示这个
阴霾天空 发表时间:2023-03-25
