H3C 5560S-EI交换机配置与恢复具体的操作步骤是啥?
2023-04-12提问
  • 0收藏,510浏览
粉丝:147人 关注:0人
您好,以下交换机恢复出厂设置的方法,请参考:
方法一:
<H3C>reset saved-configuration   //清空交换机配置
The saved configuration file will be erased. Are you sure? [Y/N]:y   //设备提示保存的配置将会被删除,是否继续。
Configuration file in flash: is being cleared. Please wait ...
MainBoard:
 Configuration file is cleared.   //配置已被清空
<H3C>reboot   //重启交换机
 Current configuration may be lost after the reboot, save current configuration? [Y/N]:n   //设备提示会在重启后丢失当前配置,是否保存当前配置,选择n
This command will reboot the device. Continue? [Y/N]:y   //设备提示设备将会重启,是否继续,选择Y
Now rebooting, please wait...
%Dec 14 20:48:39:352 2019 SW1 DEV/5/SYSTEM_REBOOT: System is rebooting now.
方法二:
<H3C>dir  //通过dir命令查看交换机的文件
Directory of flash:
   0 drw-           - Dec 14 2019 20:37:24   diagfile
   1 -rw-        1554 Dec 14 2019 20:50:06   ifindex.dat
   2 -rw-       21632 Dec 14 2019 20:37:24   licbackup
   3 drw-           - Dec 14 2019 20:37:24   license
   4 -rw-       21632 Dec 14 2019 20:37:24   licnormal
   5 drw-           - Dec 14 2019 20:48:38   logfile
   6 -rw-           0 Dec 14 2019 20:37:24   s5820v2_5830v2-cmw710-boot-a7514.bin
   7 -rw-           0 Dec 14 2019 20:37:24   s5820v2_5830v2-cmw710-system-a7514.bin
   8 drw-           - Dec 14 2019 20:37:24   seclog
   9 -rw-        6118 Dec 14 2019 20:50:06   startup.cfg  //这个是启动的交换机配置,我们要删除此文件
  10 -rw-      110464 Dec 14 2019 20:50:06   startup.mdb
1046512 KB total (1046300 KB free)
<H3C>delete startup.cfg   //使用删除命令删除startup.cfg这个启动运行的配置文件
Delete flash:/startup.cfg? [Y/N]:y   //设备提示是否要删除,选择Y
Deleting file flash:/startup.cfg... Done.   //设备提示startup.cfg这个文件已删除完成
<H3C>reboot   //重启交换机
