3PAR存储管理虚机SSMC3.8.3需要禁用SSH服务
2023-04-13提问
  • 1收藏,975浏览
粉丝:1人 关注:13人
客户的3PAR存储管理虚机SSMC3.8.3,已升级到现在的最新的SSMC版本,但客户漏洞扫描还是查到SSMC管理虚机的SSH版本偏低,现在需要禁用ssh服务,在ssmcadmin账户下,无权限禁用SSH服务,需要root权限。
1、SSMC3.8.3怎么禁用SSH服务呢?
2、SSMC3.8.3禁用SSH服务,对管理3PAR存储,有没有什么影响呢?
3、SSMC3.8.3怎么进root用户呢?
粉丝:24人 关注:0人
可以尝试用iptables允许/禁用特定客户端访问SSH
用sudo实现root权限
Authenticated sudo permissions
The default SSMC appliance does not expect the user to provide password each time they attempt to escalate their privilege using sudo grants. Standards security requires that whenever there is a request for privilege escalation, the user password is required.
Execute the following command to configure password to be required for ssmcadmin, whenever a privilege escalation is requested using the sudo facility:sudo /ssmc/bin/config_security.sh -o sudo_password -a enable
Execute the following command to reset the sudo password requirement at every privilege escalation event using the sudo facility:sudo /ssmc/bin/config_security.sh -o sudo_password -a disable
