h3c防火墙和ciscoASA 对接VPN
2017-08-25提问
  • 1收藏,2750浏览
公司本来用两台H3C防火墙做ipsec-vpn 但是有一台坏了,然后那一台csico的ASA代替,但是对接过程中vpn建立不成功
想问问:
ike peer branch1
 exchange-mode aggressive
 pre-shared-key simple 12348765abc
 id-type name
 remote-name branch1
 nat traversal
这里的指向关系是不是要指定ASA的地址的 啊
一下为H3C防火墙上的配置
 ike local-name center
acl number 3000
 rule 0 deny ip destination 192.168.47.0 0.0.0.255
 rule 15 permit ip destination 172.16.106.73 0
 rule 20 permit ip destination 172.16.114.15 0
acl number 3100
 rule 0 permit ip source 192.168.0.0 0.0.255.255 destination 192.168.47.224 0.0.0.31
 rule 5 permit ip source 172.0.0.0 0.255.255.255 destination 192.168.47.224 0.0.0.31
 rule 10 permit ip source 10.0.0.0 0.255.255.255 destination 192.168.47.224 0.0.0.31
acl number 3200
 rule 0 permit ip source 192.168.0.0 0.0.255.255 destination 192.168.47.0 0.0.0.31
 rule 5 permit ip source 172.0.0.0 0.255.255.255 destination 192.168.47.0 0.0.0.31
 rule 10 permit ip source 10.0.0.0 0.255.255.255 destination 192.168.47.0 0.0.0.31
ike peer branch1
 id-type name
 remote-name branch1
 nat traversal
ike peer branch2
 id-type name
 remote-name branch2
 nat traversal
ipsec proposal 1
ipsec policy center 2 isakmp
 security acl 3200
 ike-peer branch2
 proposal 1
user-group system
interface NULL0
interface GigabitEthernet0/0
 port link-mode route
 ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet0/1
 ip address 192.168.14.252 255.255.255.0
interface GigabitEthernet0/2
 nat outbound 3000
 ip address 10.154.81.1 255.255.255.0
 ipsec policy center
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface Tunnel0
 ip address 10.1.2.1 255.255.255.0
 source 10.154.81.1
 ip route-static 0.0.0.0 0.0.0.0 10.154.81.254
 ip route-static 10.0.0.0 255.255.255.0 192.168.14.254
 ip route-static 172.0.0.0 255.0.0.0 192.168.14.254
 ip route-static 172.16.106.0 255.255.255.0 10.154.81.254
 ip route-static 172.16.114.0 255.255.255.0 10.154.81.254
 ip route-static 192.168.0.0 255.255.0.0 192.168.14.254
 ip route-static 192.168.47.0 255.255.255.224 10.154.81.254
 ip route-static 192.168.47.224 255.255.255.224 Tunnel0
 load xml-configuration
 load tr069-configuration
看你配置,H3C设备是总部,用的野蛮模式,思科也要配置野蛮模式,并且id-type要是name,思科的name要和H3C上配置的remote-name一致才行,还有ike proposal、ipsec proposal参数也要一致,安全acl要配置成镜像。
这个是可以的,但是cisco的野蛮模式不会配啊,然后H3C的设备制定对象可以不
zhiliao_27658 发表时间:2017-08-28
