S10508X核心交换机日志问题
2023-04-14提问
  • 0收藏,1071浏览
%Apr 13 15:12:24:061 2023 DG-S10508X DRVPLAT/4/SOFTCAR DROP: -Chassis=1-Slot=9; PktType= IPV4_TTL , srcMAC=b044-1467-7635, Drop From Interface=FortyGigE1/9/0/2 at Stage=19, StageCnt=16791, TotalCnt=490464 %Apr 13 17:40:41:618 2023 DG-S10508X DRVPLAT/4/SOFTCAR RECOVER: -Chassis=1-Slot=7; PktType= IPV4_TTL , recieve pps=33, Interface=FortyGigE1/7/0/2 %Apr 13 17:56:54:688 2023 DG-S10508X DRVPLAT/4/SOFTCAR DROP: -Chassis=1-Slot=7; PktType= IPV4_TTL , srcMAC=b044-1467-75f9, Drop From Interface=FortyGigE1/7/0/2 at Stage=0, StageCnt=125, TotalCnt=125 %Apr 13 18:06:58:457 2023 DG-S10508X DRVPLAT/4/SOFTCAR DROP: -Chassis=1-Slot=7; PktType= IPV4_TTL , srcMAC=b044-1467-75f9, Drop From Interface=FortyGigE1/7/0/2 at Stage=0, StageCnt=28516, TotalCnt=28641 %Apr 13 18:13:24:584 2023 DG-S10508X DRVPLAT/4/SOFTCAR DROP: -Chassis=1-Slot=9; PktType= IPV4_TTL , srcMAC=b044-1467-7635, Drop From Interface=FortyGigE1/9/0/2 at Stage=62, StageCnt=80927, TotalCnt=571391 %Apr 13 18:17:02:174 2023 DG-S10508X DRVPLAT/4/SOFTCAR DROP: -Chassis=1-Slot=7; PktType= IPV4_TTL , srcMAC=b044-1467-75f9, Drop From Interface=FortyGigE1/7/0/2 at Stage=0, StageCnt=32912, TotalCnt=61553 %Apr 13 18:27:05:863 2023 DG-S10508X DRVPLAT/4/SOFTCAR DROP: -Chassis=1-Slot=7; PktType= IPV4_TTL , srcMAC=b044-1467-75f9, Drop From Interface=FortyGigE1/7/0/2 at Stage=0, StageCnt=41308, TotalCnt=102861 %Apr 13 19:13:46:193 2023 DG-S10508X DRVPLAT/4/SOFTCAR DROP: -Chassis=1-Slot=9; PktType= IPV4_TTL , srcMAC=b044-1467-7635, Drop From Interface=FortyGigE1/9/0/2 at Stage=63, StageCnt=337718, TotalCnt=909109 %Apr 13 19:27:29:293 2023 DG-S10508X DRVPLAT/4/SOFTCAR DROP: -Chassis=1-Slot=7; PktType= IPV4_TTL , srcMAC=b044-1467-75f9, Drop From Interface=FortyGigE1/7/0/2 at Stage=63, StageCnt=421178, TotalCnt=524039
以上是日志信息
粉丝:119人 关注:1人
SOFTCAR DROP   //softcar的报文被丢弃。
需检查下端口的各类型的数据包收发的情况,参考命令如下:
dis counter inbound interface
 dis counter outbound interface
不排除设备及CPU接收的数据报文过多。
粉丝:13人 关注:11人
记录了在不同的时间点发生的一系列 DROP(丢弃)事件。根据日志中的信息,这些 DROP 事件似乎与 IPV4_TTL(IPv4 包的生存时间)有关,并涉及到不同的接口(FortyGigE1/7/0/2 和 FortyGigE1/9/0/2)以及不同的阶段(Stage)。具体原因可能需要进一步的调查和分析。
这些日志中的 DROP 事件可能是由于某些网络配置或配置错误导致的,例如包的生存时间超过了设定的阈值而被丢弃。也可能是由于网络流量过大、设备性能不足或硬件故障等原因导致的。解决这些问题可能需要进行深入的网络故障排除和性能分析,例如检查交换机的配置,检查接口的状态和统计信息,分析网络流量模式,以及检查硬件健康状态等。
