场地使用两台H3C 7503-M作为核心层,配置IRF;汇聚层使用H3C 6800-2C,配置IRF,
最近检查发现logbuffer 出现大量的"STP/6/STP_NOTIFIED_TC"的通知信息,如下:
核心层:H3C 7503-M IRF
######################################################################################################## %Apr 20 08:48:44:904 2023 CNHSW001 STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation11 was notified a topology change. %Apr 20 08:48:46:299 2023 CNHSW001 STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation12 was notified a topology change. %Apr 20 08:48:47:050 2023 CNHSW001 STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation11 was notified a topology change. %Apr 20 08:56:55:591 2023 CNHSW001 STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation11 was notified a topology change. %Apr 20 08:56:56:503 2023 CNHSW001 STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation11 was notified a topology change. %Apr 20 08:56:56:845 2023 CNHSW001 STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation12 was notified a topology change. %Apr 20 08:56:56:959 2023 CNHSW001 STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation11 was notified a topology change. %Apr 20 08:56:57:486 2023 CNHSW001 STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation12 was notified a topology change. %Apr 20 08:56:58:662 2023 CNHSW001 STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation11 was notified a topology change. ########################################################################################################
汇聚层:H3C 6800-2C IRF
######################################################################################################## %Apr 19 08:58:07:859 2023 CNHSW101 STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change. %Apr 19 08:58:10:835 2023 CNHSW101 STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change. %Apr 19 09:11:23:657 2023 CNHSW101 STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change. %Apr 19 09:11:25:833 2023 CNHSW101 STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change. %Apr 19 09:11:26:973 2023 CNHSW101 STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change. %Apr 19 09:11:29:833 2023 CNHSW101 STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation1 was notified a topology change. ##################################################################
但是检查发现两者出现的拓扑变更通知信息不是相同的。
问题:
(1)生产中配置的IRF技术,为什么日志会出现大量的"STP/6/STP_NOTIFIED_TC"日志?
(2)运行配置文件有
"# stp instance 0 root primary stp bpdu-protection stp global enable #", 但是IRF 不是已经认为是无环路的机制吗?
(3)如何进一步诊断以上出现的STP通知有关的端口和预防拓扑变更出现的问题?
(0)
IRF技术本身并不会直接导致STP通知信息的出现,但是在使用IRF技术时,可能会出现端口状态变化,从而引发STP通知信息的出现。例如,当IRF成员端口出现故障或者配置变化时,可能会导致IRF成员端口状态变化,从而触发STP通知信息的出现。
IRF技术可以确保网络无环路,但是STP技术仍然是必要的。因为即使网络无环路,也可能存在多个路径可以到达同一目的地,从而导致网络拓扑变化。STP技术可以检测并防止这种情况发生,确保网络的稳定性和可靠性。
如果出现大量的STP通知信息,可以通过以下方法进一步诊断和预防拓扑变更出现的问题:使用命令"dis stp topology"查看当前网络的STP拓扑情况,确认是否存在环路或者不稳定的拓扑结构。 使用命令"dis stp interface"查看各个接口的STP状态和参数,确认是否存在异常的接口或者配置。 使用命令"dis irf"查看IRF状态和参数,确认IRF是否正常工作,并且成员端口状态是否稳定。对网络进行全面的巡检和诊断,包括物理连接、接口状态、配置参数、网络拓扑等方面,确认是否存在异常或者不稳定的因素。 对网络进行优化和调整,例如调整STP参数、重新配置IRF、更换故障设备等,以提高网络的稳定性和可靠性。
(1)
您好!
按照你的意思,我查了
核心层:
"port Bridge-Aggregation11"的配置如下:
interface Bridge-Aggregation11
description DYMNCxx ----》连接另外场地交换机
port link-type trunk
port trunk permit vlan 1 101 to 102
link-aggregation mode dynamic
汇聚层:
"port Bridge-Aggregation1" 配置如下:
description CNHSW001 --》上联核心交换机
port trunk permit vlan 1 to 4
其中是否缺少你说的边缘端口配置信息?如何配置?
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
