WX3540X debugging dot1x all调试信息分析
2023-04-25提问
  • 0收藏,533浏览
AC上配置的802.1x认证,但是debug信息时,发现卡在如下地方:
RADIUS/7/EVENT: PAM_RADIUS: Processing RADIUS authentication.//进行RADIUS认证
RADIUS/7/EVENT: PAM_RADIUS: Sent authentication request successfully.// 成功发送认证请求
RADIUS/7/EVENT: Processing AAA request data.// 处理AAA请求数据
RADIUS/7/EVENT: Got request data successfully, primitive: authentication.// 成功接收到用户的认证请求,原语是认证
RADIUS/7/EVENT: Getting RADIUS server info.
RADIUS/7/EVENT: Got RADIUS server info successfully.// 成功获取RADIUS服务器信息
RADIUS/7/EVENT: Created request context successfully.// 成功创建请求上下文
RADIUS/7/EVENT: Created request packet successfully, dstIP: x.x.x.x, dstPort: 1812, VPN instance: --(public), socketFd: 334, pktID: 8.// 成功创建认证请求报文,目的地址是x.x.x.x,目的端口是1812,VPN实例是public,套接字是334,报文ID是8
RADIUS/7/EVENT: Added packet socketfd to epoll successfully, socketFd: 334.
RADIUS/7/EVENT: Mapped PAM item to RADIUS attribute successfully.// 成功将PAM数据项映射为RADIUS属性
RADIUS/7/EVENT: Got RADIUS username format successfully, format: 0.
RADIUS/7/EVENT: Added attribute user-name successfully, user-name: test.// 成功添加用户名属性,属性值是test
RADIUS/7/EVENT: Filled RADIUS attributes in packet successfully.// 成功填充报文属性,并构建认证请求报文
RADIUS/7/EVENT: Composed request packet successfully.
RADIUS/7/EVENT: Created response timeout timer successfully.// 成功创建应答超时定时器
RADIUS/7/EVENT: Sent request packet and create request context successfully.// 成功发送认证请求报文,并创建请求上下文
RADIUS/7/EVENT: Added request context to global table successfully.// 成功将请求上下文加入全局上下文信息表
RADIUS/7/EVENT: Response timed out. //响应超时
RADIUS/7/EVENT: Found request context, dstIP: x.x.x.x; dstPort: 1812; VPN instance: --(public); socketfd: 334; pktID:8.// 查找到请求上下文
RADIUS/7/EVENT: Retransmitting request packet, currentTries: 2, maxTries: 3.  //然后开始重新认证
请帮忙看看这是为什么?需要去排查哪里呢?
粉丝:23人 关注:2人
radius1号报文发出去了么,服务器有回复么
不确定是否发出去了,但是服务器端没有收到任何请求报文
zhiliao_lkta9w 发表时间:2023-04-25
Sent request packet and create request context successfully看起来报文是发出去了,debug没有打印radius packet么?可以抓包看看
爱吃胡萝卜 发表时间:2023-04-25
