设备断电,网络丢失
2023-04-26提问
  • 0收藏,507浏览
设备断电后,网络断了,有线和无线都掉了,我是新来的IT,工作没交接,光纤连接的汇聚层交换机-上网行为-防火墙-路由器,这种接法有没问题?应该如何快速恢复网络,盼各位给予指导,谢谢。
8 个回答
7_7 二段
粉丝:0人 关注:2人
接法没问题吧 所有配置都丢失了吗
粉丝:119人 关注:1人
1、先确保所有设备都加电
2、检查所有设备配置,从console进去确认
3、可以先简单的检查下,级联线路是否灯亮
zhiliao_wTqaCI 知了小白
不确定是否丢失配置,在如何console中如何确认?
dis cur 一下  如果配置没丢按照接口属性连接。
zhiliao_wTqaCI 知了小白
看了下汇聚层交换机配置没丢,但网络断了
zhiliao_wTqaCI 知了小白
H3C> %Apr 26 16:14:34:064 2023 H3C SHELL/5/SHELL_LOGIN: Console logged in from con0. dis cur # version 7.1.064, Release 0707P15 # sysname H3C # telnet server enable # nat static inbound 60.174.68.209 192.168.10.251 nat static outbound 192.168.10.251 60.174.68.209 # dhcp enable dhcp server always-broadcast # dns proxy enable # password-recovery enable # vlan 1 # object-group ip address default 0 network range 192.168.20.3 192.168.20.254 # dhcp server ip-pool lan1 ---- More ----%Apr 26 16:14:42:805 2023 H3C DEV/2/FAN_FAILED: Fan 1 failed. gateway-list 192.168.0.1 network 192.168.0.0 mask 255.255.254.0 address range 192.168.1.2 192.168.1.254 dns-list 192.168.0.1 # controller Cellular0/0 # interface Virtual-Template0 # interface NULL0 # interface LoopBack0 ip address 192.168.150.1 255.255.255.0 # interface Vlan-interface1 # interface GigabitEthernet0/0 port link-mode route ---- More ----%Apr 26 16:16:02:805 2023 H3C DEV/2/FAN_FAILED: Fan 1 failed. combo enable copper ip address 60.174.68.209 255.255.255.0 nat outbound 3000 nat server protocol tcp global 60.174.68.209 2443 inside 192.168.20.254 443 nat server protocol tcp global 60.174.68.209 3443 inside 192.168.100.254 443 nat server protocol tcp global 60.174.68.209 4443 inside 192.168.120.1 443 nat server protocol tcp global 60.174.68.209 8888 inside 192.168.10.113 8088 nat server protocol tcp global 60.174.68.209 9999 inside 192.168.10.113 3389 nat server protocol tcp global current-interface 8380 inside 192.168.10.251 8380 nat server protocol tcp global current-interface 8433 inside 192.168.10.251 9433 nat static enable # interface GigabitEthernet0/1 port link-mode route ---- More ----%Apr 26 16:17:22:805 2023 H3C DEV/2/FAN_FAILED: Fan 1 failed.
粉丝:1人 关注:1人
工作还没交接就先找原来的运维来看啊,交接了才是你的事吧
zhiliao_wTqaCI 知了小白
原来的IT跑路了
