MSR3600系列如何display pppoe用户的详细信息
2023-05-06提问
  • 0收藏,435浏览
在WAC360系列上能够使用 display connection xxx列出用户的user-profile,SessionTimeout等信息,
想问下MSR3600系列上,是用什么命令?
lynatgz 知了小白
[MSR3600-xijie-26]dis ppp access-user user-type pppoe
Interface Username MAC address IP address IPv6 address IPv6 PDPrefix
VA1 70434514 d4da-21ab-a07a 172.16.3.53 - -
VA2 95447486 5089-6527-4213 172.16.3.51 - -
VA3 90165701 503a-a0ca-dcf1 172.16.3.50 - -
VA5 35913799 6464-4a2e-2ff2 172.16.3.65 - -
VA6 70823934 487d-2e56-bea9 172.16.3.60 - -
VA9 100503 005c-8614-f9ff 172.16.3.54 - -
VA12 05595339 3ccd-57a4-096e 172.16.3.57 - -
VA13 21072497 503a-a0c2-6a11 172.16.3.59 - -
VA14 17416732 b095-8e47-b114 172.16.3.55 - -
VA15 08092094 1c60-de9f-2b9f 172.16.3.56 - -
VA16 26554257 503a-a0ce-c0fb 172.16.3.58 - -
VA17 57999160 081f-715d-dcde 172.16.3.52 - -
VA18 87776634 cc2d-21ea-8d68 172.16.3.62 - -
VA19 zhouliyi 00e0-4c70-ac0b 172.16.3.61 - -
ng
[MSR3600-xijie-26]dis ppp access-user username 70434514
Basic:
Interface: VA1
User ID: 0x28000006
Username: 70434514
Domain: chap_auth_domain
Access interface: Vlan3
Service-VLAN/Customer-VLAN: 3/-
MAC address: d4da-21ab-a07a
IP address: 172.16.3.53
IPv6 address: -
IPv6 PD prefix: -
VPN instance: -
Access type: PPPoE
Authentication type: CHAP
AAA:
Authentication state: Authenticated
Authorization state: Authorized
Realtime accounting switch: Closed
Realtime accounting interval: -
Login time: 2023-04-27 19:34:40:81
Accounting start time: -
Online time(hh:mm:ss): 219:51:09
Accounting state: Stop
Idle cut: 86400 sec 10240 byte
Session timeout: -
Time remained: -
Traffic quota: -
Traffic remained: -
Redirect WebURL: -
ACL&QoS:
User profile: -
User group profile: -
Inbound CAR: CIR 5000000bps PIR 6000000bps CBS N/A (active)
Outbound CAR: CIR 30000000bps PIR 35000000bps CBS N/A (active)
Flow Statistic:
IPv4 uplink packets/bytes: 0/0
IPv4 downlink packets/bytes: 12956379/14907706296
IPv6 uplink packets/bytes: 0/0
IPv6 downlink packets/bytes: 0/0
找到了
粉丝:6人 关注:0人
MSR3600系列上,可以使用以下命令来列出用户的user-profile和SessionTimeout等信息:
  1. 显示当前用户的user-profile信息:
display user-profile
  1. 显示所有用户的SessionTimeout信息:
display aaa online-user
其中,SessionTimeout信息在“Idle Time”一列中显示
粉丝:0人 关注:3人
360是v5的,建议参考v7的命令手册https://www.h3c.com/cn/Service/Document_Software/Document_Center/Routers/Catalog/ICT/MSR3600_ICT/?category=331904&subcategory=331916
