s5130怎么清除console密码,但是配置需要保留。
2023-05-09提问
  • 0收藏,675浏览
粉丝:144人 关注:0人
您好,参考
V7交换机Console密码忘记处理方法
V7交换机Console密码忘记处理方法 1
1 配置需求或说明 1
1.1 适用产品系列 1
1.2 配置需求及实现的效果 1
2 组网图 1
3 配置步骤 2
3.1 进入bootroom菜单清除Consle密码 2
3.2 如果不需要之前的配置信息的话 3
3.3 如果需要之前的配置信息的话 3
配置需求或说明
1.1 适用产品系列
本案例适用于如S5130-28F-WiNetS5500V2-24P-WiNetS5500V2-48P-WiNet等的V7交换机,V5V7交换机具体分类及型号可以参考“1.1 Comware V5V7平台交换机分类说明”。
1.2 配置需求及实现效果
清除Consle密码,恢复出厂
组网图
配置步骤
通过conlse线crt软件连接并登陆设备,然后把设备断电重启。控制台上会打印如下信息,当出现“press Ctrl+B”时候快速按住“Ctrl+B” 进入botroom菜单
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing.......................Done!
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
BotWare password: Not required. Please press Enter to continue.
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
      按住“Ctrl+B”进入如下菜单。选择<6> Skip Current System Configuration跳过当前配置启动,不同设备可能不是数字6,
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTEND-ASSISTANT MENU
Ctrl+F: Format File System
Enter your choice(0-9): 6
Flag Set Success.
然后输入0重启设备
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 0
Press ENTER to get started.
3.2 如果不需要之前的配置信息的话
操作步骤:跳过启动文件后直接保存当前配置,再重启。
<H3C>save
The current configuration will be written to the device. Are you sure? [Y/N]:y
Please input the file name(*.cfg)[flash:/startup.cfg]
(To leave the existing filename unchanged, press the enter key):(输入回车)
flash:/startup.cfg exists, overwrite? [Y/N]:y
Validating file. Please wait...
Configuration is saved to device successfully.
<H3C>reboot
Start to check configuration with next startup configuration file, please wait.........DONE!
Current configuration may be lost after the reboot, save current configuration? [Y/N]:y
This command will reboot the device. Continue? [Y/N]:y
3.3 如果需要之前的配置信息的话
<H3C>
#Apr 26 12:02:07:166 2000 H3C SHELL/4/LOGIN:
 Trap 1.3.6.1.4.1.25506.2.2.1.1.3.0.1<hh3cLogIn>: login from Console
%Apr 26 12:02:07:306 2000 H3C SHELL/5/SHELL_LOGIN: Console logged in from aux0.
<H3C>dir  %查看设备配置文件
Directory of flash:/
   1     drw-         -  Apr 26 2000 12:00:20   logfile
   2     -rw-      1666  Apr 26 2000 12:05:39   startup.cfg
   3     -rw-      1556  Apr 26 2000 12:05:33   _startup_bak.cfg
   4     -rw-       151  Apr 26 2000 12:05:30   system.xml
29106 KB total (16876 KB free)
给设备和电脑配置成同网段IP地址(举例:WAC配置成192.168.100.1,电脑配置成192.168.100.2),在电脑上通过3CD软件搭建tftp服务器。
<H3C>sys
System View: return to User View with Ctrl+Z.
[H3C]interface Vlan-interface 1
[H3C-Vlan-interface1]ip address 192.168.100.1 24
[H3C-Vlan-interface1]quit
[H3C]ping 192.168.100.2
  PING 192.168.100.2: 56  data bytes, press CTRL_C to break
    Reply from 192.168.100.2: bytes=56 Sequence=1 ttl=128 time=7 ms
    Reply from 192.168.100.2: bytes=56 Sequence=2 ttl=128 time=2 ms
<H3C>tftp 192.168.100.2 put startup.cfg
  File will be transferred in binary mode
  Sending file to remote TFTP server. Please wait... |
  TFTP:     1666 bytes sent in 0 second(s).
  File uploaded successfully.
<H3C>
下载成功:
可以到本地相关路径(此例子中是E盘)查看到相关文件。
需要恢复之前配置
解决方法:删除密码恢复之前配置文件
使用记事本打开startup.cfg文件
删除aux0口下的认证方式和密码并保存文件
覆盖当前配置文件
<H3C>tftp 192.168.100.20 get startup.cfg
The file startup.cfg exists. Overwrite it? [Y/N]:y
  Verifying server file...
  Deleting the old file, please wait...
  Downloading file from remote TFTP server, please wait....
  TFTP:     1166 bytes received in 0 second(s)
  File downloaded successfully.
<H3C>reboot
Current configuration may be lost after the reboot, save current configuration? [Y/N]:n 不保存配置
This command will reboot the device. Continue? [Y/N]:y 确定继续重启
粉丝:94人 关注:0人
重启boot菜单清除
这个看有没有配置undo pass en,配置了就抹除不掉。只能还原。你在boot才到按跳过,过不了就是配置了。
粉丝:119人 关注:1人
修改认证方式为none即可:
配置通过Console口登录设备
1. 配置通过Console口登录设备时无需认证(none)
用户已经成功登录到了设备上,并希望以后通过Console口登录设备时无需进行认证。
表3-3 配置用户通过Console口登录设备时无需认证
进入AUX用户线视图
line aux first-number [ last-number ]
二者选其一
·     用户线视图下的配置优先于用户线类视图下的配置
·     用户线视图下的配置只对该用户线生效且立即生效
·     用户线类视图下的配置修改不会立即生效,当用户下次登录后所修改的配置值才会生效
·     用户线视图下的属性配置为缺省值时,将采用用户线类视图下配置的值。如果用户线类视图下的属性配置也为缺省值,则直接采用该属性的缺省值
进入AUX用户线类视图
line class aux
设置登录用户的认证方式为不认证
authentication-mode none
缺省情况下,用户通过Console口登录,认证方式为none
配置从当前用户线登录设备的用户角色
user-role role-name
缺省情况下,通过Console口登录设备的用户角色为network-admin。
