MSG360 加入AP组后,能不能自动绑定无线射频
2023-05-12提问
  • 0收藏,470浏览
AP组里有设置无线服务,新AP加入后,并不会添加无线服务,这个能设置自动化吗?
4 个回答
粉丝:154人 关注:1人
默认加入组就是会集成组的配置
组的型号配置了,新AP会自动加入组,但是不会继承组的无线
zhiliao_MJ4YX 发表时间:2023-05-12
去无线服务中绑定ap组,之后该组上线的ap会自动绑定射频
ap组有绑定射频,但是自动上线并入组的ap并没有自动加入射频
回复zhiliao_MJ4YX:
ap组下有绑定ap模板吗
网工大白 发表时间:2023-05-12
回复网工大白:
没有,是绑定map那里吗? 这块我不是很了解,有文档资料或者简单配置参考一下吗?
粉丝:171人 关注:8人
配置相应型号就可以继承
回复zhiliao_MJ4YX:
上配置看下
zhiliao_sEUyB 发表时间:2023-05-12
# version 7.1.064, Release 5446P06 # sysname H3C # clock timezone Beijing add 08:00:00 clock protocol ntp # wlan global-configuration calibrate-channel self-decisive enable all calibrate-power self-decisive enable all # telnet server enable # dhcp enable # lldp global enable # password-recovery enable # vlan 1 # vlan 9 # vlan 12 # vlan 15 to 17 # vlan 31 # vlan 111 # dhcp server ip-pool 1 gateway-list 192.168.0.100 network 192.168.0.0 mask 255.255.255.0 dns-list 192.168.0.100 # wlan service-template h3c-g-9e73a8 ssid H3C-G-9E73A8 # wlan service-template vlan9 ssid Vlan9 vlan 9 user-isolation enable service-template enable # wlan service-template vlan12 ssid Vlan12 vlan 12 service-template enable # wlan service-template vlan15 ssid Vlan15 vlan 15 akm mode psk preshared-key pass-phrase cipher $c$3$21W3OrW0AuZDkuwx/PSkxw6v0Y39CZO7KfvzMIw= cipher-suite ccmp cipher-suite tkip security-ie rsn security-ie wpa service-template enable # wlan service-template vlan16 ssid Vlan16 vlan 16 akm mode psk preshared-key pass-phrase cipher $c$3$rXvnTMtBXiZR+D3IOpgVc34AXn2+NdywLl4A+lo= cipher-suite ccmp cipher-suite tkip security-ie rsn security-ie wpa service-template enable # wlan service-template vlan17 ssid Vlan17 vlan 17 service-template enable # wlan service-template vlan31 ssid Vlan31 vlan 31 service-template enable # wlan service-template vlan111 ssid vlan111 vlan 111 beacon ssid-hide service-template enable # interface NULL0 # interface Vlan-interface1 ip address 192.168.0.100 255.255.255.0 # interface Vlan-interface9 ip address 192.168.9.10 255.255.255.0 # interface Vlan-interface12 ip address 192.168.12.10 255.255.255.0 # interface Vlan-interface15 ip address 192.168.15.10 255.255.255.0 # interface Vlan-interface16 ip address 192.168.16.10 255.255.255.0 # interface Vlan-interface17 ip address 192.168.17.10 255.255.255.0 # interface Vlan-interface31 # interface Vlan-interface111 ip address 192.168.111.210 255.255.255.192 # interface GigabitEthernet1/0/5 port link-mode route ip address dhcp-alloc nat outbound undo dhcp select server # interface GigabitEthernet1/0/1 port link-mode bridge port link-type trunk undo port trunk permit vlan 1 port trunk permit vlan 9 12 15 to 17 31 111 # interface GigabitEthernet1/0/2 port link-mode bridge # interface GigabitEthernet1/0/3 port link-mode bridge # interface GigabitEthernet1/0/4 port link-mode bridge port access vlan 9 # scheduler logfile size 16 # line class console user-role network-admin # line class vty user-role network-operator # line con 0 user-role network-admin # line vty 0 31 authentication-mode scheme user-role network-operator # undo info-center logfile enable # domain system # domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # local-user admin class manage password hash $h$6$PJzQEaeYoGJ68x7k$tdPXP8ZlHfErO+xGBgciwfDtTER+pj+Of5PR+AKfpr5+A8ogSdsLpenj5x4OfRu8KAFwhzWGvRbcC0YLhCRqkA== service-type telnet http https authorization-attribute user-role network-admin # netconf soap http enable # ip http enable ip https enable # smartmc tm username admin password cipher $c$3$pwv4+OgLVNydPRHKC2R0GkzydWlWnA7j enable # wlan auto-ap enable wlan auto-persistent enable wlan tcp mss 1360 # wlan ap-group default-group vlan 1 # wlan ap-group vlan15 vlan 1 ap 00DD-B6B8-4780 ap 00dd-b6b8-35a0 ap 00dd-b6b8-5b80 ap 00dd-b6b8-b5c0 ap 00dd-b6b8-b760 ap-model WAP722S-W2 radio 1 radio enable service-template vlan15 radio 2 radio enable service-template vlan15 gigabitethernet 1 # wlan virtual-ap-group default-virtualapgroup # wlan ap 00DD-B6B8-4780 model WAP722S-W2 mac-address 00dd-b6b8-4780 description F5 ���� vlan 1 radio 1 service-template vlan15 radio 2 service-template vlan15 gigabitethernet 1 # wlan ap 00dd-b6b8-35a0 model WAP722S-W2 serial-id 219801A1GW821BE003J1 description �ܾ��� vlan 1 radio 1 service-template vlan15 service-template vlan16 radio 2 service-template vlan15 gigabitethernet 1 # wlan ap 00dd-b6b8-5b80 model WAP722S-W2 serial-id 219801A1GW821BE003TT vlan 1 radio 1 radio 2 gigabitethernet 1 # wlan ap 00dd-b6b8-b760 model WAP722S-W2 serial-id 219801A1GW821BE004LJ description ���� vlan 1 radio 1 service-template vlan15 radio 2 service-template vlan15 gigabitethernet 1 # wlan ap 00dd-b6b8-b5c0 model WAP722S-W2 serial-id 219801A1GW821BE004L3 description ��ó�IJ� vlan 1 radio 1 service-template vlan16 radio 2 service-template vlan16 gigabitethernet 1 # cloud-management server domain cloudnet.h3c.com # return
回复zhiliao_MJ4YX:
太乱了
回复zhiliao_sEUyB:
评论里不换行,我放下面的回答里面了
回复zhiliao_MJ4YX:
AP上线后需要移动到vlan15组里 才能发信号
zhiliao_MJ4YX 知了小白
组的型号配置了,新AP会自动加入组,但是不会继承组的无线,一下是配置
