UIS升级预检查报错,提示主机检查包列表、依赖关系树和状态信息有错误。请在升级前修复错误。
2023-05-13提问
  • 0收藏,807浏览
UIS升级预检查报错提示:
[WARN] Hosts (192.168.1.130 192.168.1.131 192.168.1.134) check package lists, dependency tree and state information have errors. Please fix errors before upgrade. [WARN] Pre-check has some WARN(s) need to be evaluated the effects.
粉丝:4人 关注:0人
先执行预检查脚本看看有什么报错
[root@cvknode1 upgrade.e0750p09h01]# ./uis_upgrade.sh precheck offline [DEBUG] Operation time: 2023-05-13 21:01:52 [INFO] Pre-check the status of UIS environment... [INFO] Collect all hosts: 192.168.1.130 192.168.1.134 192.168.1.131 [INFO] This host is CVM or CVK? [CVM|CVK]: cvm [INFO] Pre-check the status of CAS environment... [INFO] Get CAS version. [INFO] The following releases are supported: centos-x86_64 ./package/cvk-centos-x86_64.tar.xz is already decompressed as ./package/cvk [ OK ] Check CAS version... Done [INFO] Get mysql/mariadb service. [ OK ] Check mariadb service... Done [INFO] Get HA service. [ OK ] Check HA service... Done [INFO] Get management platform compontent. [INFO] The CAS management platform contains compontents: 'CVM' [ OK ] Check management platform compontent... Done [INFO] Get tomcat service. [ OK ] Check tomcat service... Done [INFO] Get security mode. [INFO] The security mode of CAS is non-confidential. [ OK ] Check security mode... Done [INFO] The environment of CAS is stand-alone system. [ OK ] Check CAS system mode... Done [INFO] A list of all hosts distribution information is as follows: Hosts of CVM: cvknode1 Hosts under the 'UISC_0': cvknode1 cvknode4 cvknode2 [INFO] Checking if root ssh is enabled... [INFO] root ssh is already enabled, nothing to be done. [INFO] Prechecking all hosts in parallel, this may take some time... [WARN] Hosts (192.168.1.130 192.168.1.134 192.168.1.131) check package lists, dependency tree and state information have errors. Please fix errors before upgrade. [WARN] Pre-check has some WARN(s) need to be evaluated the effects. 没报其它错,只是最后出现这个
zhiliao_4JYLJ7 发表时间:2023-05-13
192.168.1.130
192.168.1.134
192.168.1.131
Hosts of CVM:
cvknode1
cvknode1
cvknode4
cvknode2
粉丝:4人 关注:0人
看看网络是不是有丢包
