S5560S-52P-SI 链路聚合异常
2023-05-16提问
  • 0收藏,478浏览
用着用着会断开,然后大概1分钟后恢复。再连接上的时候debug模式看lacp报文是正常的。
【SW_核心】的日志
%May 16 17:19:13:346 2023 SW_核心 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/5 changed to up. %% 17:19:13:346 2023 SW_核心 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/5 changed to up. % 17:19:13:224 2023 SW_核心 LAGG/6/LAGG_ACTIVE: Member port GE2/0/5 of aggregation group BAGG5 changed to the active state. % 17:19:11:510 2023 SW_核心 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/5 changed to up. % 17:19:11:469 2023 SW_核心 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/5 changed to down. % 17:19:11:354 2023 SW_核心 LAGG/6/LAGG_INACTIVE_PARTNER: Member port GE2/0/5 of aggregation group BAGG5 changed to the inactive state, because the aggregation configuration of its peer port is incorrect. % 17:19:11:353 2023 SW_核心 LAGG/6/LAGG_ACTIVE: Member port GE1/0/5 of aggregation group BAGG5 changed to the active state. % 17:18:54:363 2023 SW_核心 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Bridge-Aggregation5 changed to up. % 17:18:54:362 2023 SW_核心 IFNET/3/PHY_UPDOWN: Physical state on the interface Bridge-Aggregation5 changed to up. % 17:18:54:297 2023 SW_核心 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/5 changed to up. % 17:18:54:219 2023 SW_核心 LAGG/6/LAGG_ACTIVE: Member port GE2/0/5 of aggregation group BAGG5 changed to the active state. % 17:18:47:424 2023 SW_核心 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Bridge-Aggregation5 changed to down. % 17:18:47:423 2023 SW_核心 IFNET/3/PHY_UPDOWN: Physical state on the interface Bridge-Aggregation5 changed to down. % 17:18:47:371 2023 SW_核心 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/5 changed to down. % 17:18:47:333 2023 SW_核心 LAGG/6/LAGG_INACTIVE_PARTNER: Member port GE2/0/5 of aggregation group BAGG5 changed to the inactive state, because the aggregation configuration of its peer port is incorrect. % 17:18:26:305 2023 SW_核心 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/5 changed to up. % 17:18:26:296 2023 SW_核心 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Bridge-Aggregation5 changed to up. % 17:18:26:290 2023 SW_核心 IFNET/3/PHY_UPDOWN: Physical state on the interface Bridge-Aggregation5 changed to up. % 17:18:26:221 2023 SW_核心 LAGG/6/LAGG_ACTIVE: Member port GE2/0/5 of aggregation group BAGG5 changed to the active state. % 17:18:17:512 2023 SW_核心 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Bridge-Aggregation5 changed to down. % 17:18:17:510 2023 SW_核心 IFNET/3/PHY_UPDOWN: Physical state on the interface Bridge-Aggregation5 changed to down. % 17:18:17:424 2023 SW_核心 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/5 changed to down. % 17:18:17:420 2023 SW_核心 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/5 changed to down. % 17:18:17:339 2023 SW_核心 LAGG/6/LAGG_INACTIVE_PARTNER: Member port GE2/0/5 of aggregation group BAGG5 changed to the inactive state, because the aggregation configuration of its peer port is incorrect. % 17:18:17:322 2023 SW_核心 LAGG/6/LAGG_INACTIVE_PARTNER: Member port GE1/0/5 of aggregation group BAGG5 changed to the inactive state, because the aggregation configuration of its peer port is incorrect.
【SW_1F】的日志
% 17:19:24:558 2023 SW_1F LAGG/5/LAGG_ACTIVE: Member port GigabitEthernet1/0/23 of aggregation group BAGG1 becomes ACTIVE. % 17:19:24:539 2023 SW_1F LAGG/5/LAGG_ACTIVE: Member port GigabitEthernet1/0/24 of aggregation group BAGG1 becomes ACTIVE. % 17:19:24:521 2023 SW_1F LAGG/5/LAGG_INACTIVE_PARTNER: Member port GigabitEthernet1/0/24 of aggregation group BAGG1 becomes INACTIVE because the port's partner is improper for being attached. % 17:19:24:474 2023 SW_1F LAGG/5/LAGG_ACTIVE: Member port GigabitEthernet1/0/24 of aggregation group BAGG1 becomes ACTIVE. % 17:19:24:474 2023 SW_1F LAGG/5/LAGG_INACTIVE_PARTNER: Member port GigabitEthernet1/0/23 of aggregation group BAGG1 becomes INACTIVE because the port's partner is improper for being attached. % 17:18:42:338 2023 SW_1F MSTP/5/MSTP_BPDU_RECEIVE_EXPIRY: Instance 0's port Bridge-Aggregation1 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out. % 17:18:32:345 2023 SW_1F LAGG/5/LAGG_INACTIVE_PARTNER: Member port GigabitEthernet1/0/24 of aggregation group BAGG1 becomes INACTIVE because the port's partner is improper for being attached.
【SW_核心】是两台设备堆叠,GE 1/0/5 和 GE2/0/5口连接交换机
【SW_1F】的GE1/0/23 和GE1/0/24
配置了动态链路聚合,和 lacp period short
粉丝:154人 关注:1人
但是两台交换机都是说对端配置异常。而他自动恢复正常后查都查不出来,开debug看lacp报文也是正常的。
zhiliao_SXpMFf 发表时间:2023-05-17
