wx3024e 日志问题
2023-05-22提问
  • 0收藏,470浏览
May 22 13:11:06:216 2023WMACInformationWMAC_CLIENT_GOES_OFFLINEClient 8030-4989-9851 disconnected from WLAN S-WORK. Reason code is 8.
May 22 13:11:04:196 2023WMACInformationWMAC_CLIENT_JOIN_WLANClient 8030-4989-9851 successfully joins WLAN S-WORK, on APID 13 with BSSID 3A8c-40f0-df30.
May 22 13:11:04:059 2023WMACInformationWMAC_CLIENT_GOES_OFFLINEClient 8030-4989-9851 disconnected from WLAN S-WORK. Reason code is 8.
May 22 13:11:02:041 2023WMACInformationWMAC_CLIENT_JOIN_WLANClient 8030-4989-9851 successfully joins WLAN S-WORK, on APID 13 with BSSID 3A8c-40f0-df30.
"Reason code is 8"是什么原因8号代码是什么意思?
粉丝:16人 关注:9人
终端正常断开连接下线
粉丝:226人 关注:0人
您好,这是终端主动离线,终端的RSSI咋样,还有射频下的配置也可以发出来看下
