模拟器中交换机做RRPP相交环
2023-05-24提问
  • 0收藏,490浏览
模拟器5.8.0中交换机做相交环。
配置完成后,发现子环master状态为failed。
SW1的相关配置;
vlan 2 to 100
 stp region-configuration
 instance 1 vlan 2 to 100
 active region-configuration
 stp global enable
 port link-mode bridge
 description ring-1-primary-port
port link-type trunk
 undo port trunk permit vlan 1
 port trunk permit vlan 2 to 100
 combo enable fiber
 link-delay 0
 undo stp enable
 description ring-1-secondary-port
 combo enable fiber
 link-delay 0
 undo stp enable
interface GigabitEthernet1/0/10
 port access vlan 10
 combo enable fiber
 rrpp domain 1
 control-vlan 4092
 protected-vlan reference-instance 1
 ring 1 node-mode master primary-port GigabitEthernet1/0/1 secondary-port GigabitEthernet1/0/2 level 0
 ring 1 enable
 rrpp enable
SW2的相关配置:
vlan 2 to 100
 stp global enable
 combo enable fiber
 link-delay 0
 undo stp enable
 combo enable fiber
 link-delay 0
 undo stp enable
 combo enable fiber
 link-delay 0
 undo stp enable
rrpp domain 1
 control-vlan 4092
 ring 1 node-mode transit primary-port GigabitEthernet1/0/1 secondary-port GigabitEthernet1/0/2 level 0
 ring 1 enable
 ring 2 node-mode edge edge-port GigabitEthernet1/0/3
 ring 2 enable
 rrpp enable
SW3的相关配置:
vlan 2 to 100
 stp global enable
 combo enable fiber
 link-delay 0
 undo stp enable
 combo enable fiber
 link-delay 0
 undo stp enable
 combo enable fiber
 link-delay 0
 undo stp enabl
rrpp domain 1
 control-vlan 4092
 ring 1 enable
 ring 2 node-mode assistant-edge edge-port GigabitEthernet1/0/3
 ring 2 enable
 rrpp enable
SW4的相关配置:
vlan 2 to 100
 stp global enable
 combo enable fiber
 link-delay 0
 undo stp enable
 combo enable fiber
 link-delay 0
 undo stp enable
 port access vlan 10
 combo enable fiber
 rrpp domain 1
 control-vlan 4092
 ring 1 enable
 rrpp enable
SW5的相关配置:
vlan 2 to 100
# stp region-configuration
 stp global enable
 combo enable fiber
 link-delay 0
 undo stp enable
 combo enable fiber
 link-delay 0
 undo stp enable
 port access vlan 10
 combo enable fiber
rrpp domain 1
 control-vlan 4092
 ring 2 node-mode master primary-port GigabitEthernet1/0/1 secondary-port GigabitEthernet1/0/2 level 1
 ring 2 enable
 rrpp enable
配置完成后dis rrpp ver d 1 显示如下
给PC1、PC2、PC3配置IP地址,分别为192.168.1.10/24、192.168.1.20/24、192.168.1.30/24,互ping不通。
SW5停止后,PC1 和PC2 互通。Down端口测试的话正常。
debug看一下报文交互
粉丝:137人 关注:8人
模拟器可能不支持
