无线管理WX3024E无法开启ssh
2023-05-25提问
  • 0收藏,370浏览
这个是配置文件
version 5.20, Release 3509P55
# sysname ylxx-ac
# domain default enable system
# telnet server enable
# lldp enable # port-security enable
 # web logbuffer size 1024
 # oap management-ip 192.168.0.101 slot 0
 # password-recovery enable
 domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
 user-group system
group-attribute allow-guest
# local-user admin
 password cipher $c$3$7brTXZ3/rN9WRkEwgPsx1nmSDi43laPbQ8QUdhqLYw==
 authorization-attribute level 3
 service-type ssh telnet
 service-type web
local-user ylxx
 password cipher $c$3$95ZQ+RU6w8tqbhFBXCjocAZRHiW8r7/IblFaV0ovTA==
 service-type ssh
 service-type web
# ssh server enable
 ssh user ylxx service-type all authentication-type password
ssh 登录就提示Received disconnect from 10.255.255.252 port 22:2: The connection is closed by SSH Server. Disconnected from 10.255.255.252 port 22
粉丝:147人 关注:0人
您好,参考
V5 ssh配置
1.生成RSA和DSA密钥对
 [H3C]public-key local create rsa
 [H3C]public-key local create dsa
2.设置用户接口上的认证模式为AAA,并让用户接口支持SSH协议
 [H3C]user-interface vty 0 4
 [H3C-ui-vty0-4]authentication-mode scheme
 [H3C-ui-vty0-4]protocol inbound ssh
3.创建用户admin,设置认证密码为luwenju-!@# 登录协议为SSH,能访问的命令级别 为  3
 [H3C]local-user admin
 [H3C-luser-admin]password cipher luwenju-!@#
 [H3C-luser-admin]service-type ssh level 3
4.指定用户admin的认证方式为password
 [H3C]ssh user admin authentication-type password
粉丝:46人 关注:1人
V5 的版本应该是需要创建密钥对把
 生成RSA和DSA密钥对
