无线本地801.x认证失败
2023-05-25提问
  • 0收藏,746浏览
<AC_primary>%May 25 16:40:46:135 2023 AC_primary DOT1X/5/DOT1X_WLAN_LOGIN_FAILURE: -Username=test-UserMAC=f09e-4aae-59b1-BSSID=54c6-fffa-ab31-SSID=teset3-APName=test1-RadioID=1-VLANID=31; A user failed 802.1X authentication.Reason:AAA processed authentication request and return 13. %May 25 16:40:46:358 2023 AC_primary DOT1X/5/DOT1X_WLAN_LOGIN_FAILURE: -Username=test-UserMAC=f09e-4aae-59b1-BSSID=54c6-fffa-ab39-SSID=teset3-APName=test1-RadioID=2-VLANID=31; A user failed 802.1X authentication.Reason:AAA processed authentication request and return 13. %May 25 16:40:46:572 2023 AC_primary DOT1X/5/DOT1X_WLAN_LOGIN_FAILURE: -Username=test-UserMAC=f09e-4aae-59b1-BSSID=54c6-fffa-94a4-SSID=teset3-APName=3F_FA_3F_liu_shui_xian-8-RadioID=1-VLANID=31; A user failed 802.1X authentication.Reason:AAA processed authentication request and return 13. %May 25 16:41:17:696 2023 AC_primary APMGR/6/RADIO: Current channel usage 91% of radio 2 on AP 3F_FA_3F_liu_shui_xian-3 exceeded the threshold. %May 25 16:41:21:626 2023 AC_primary DOT1X/5/DOT1X_WLAN_LOGIN_FAILURE: -Username=-UserMAC=f09e-4aae-59b1-BSSID=8c94-6af4-3cbc-SSID=teset3-APName=3F_FA_3F_cheng_pin_che_jian-1-RadioID=2-VLANID=31; A user failed 802.1X authentication.Reason:Received log off when user is authenticating. %May 25 16:41:24:786 2023 AC_primary DOT1X/5/DOT1X_WLAN_LOGIN_FAILURE: -Username=test-UserMAC=f09e-4aae-59b1-BSSID=54c6-fffa-922c-SSID=teset3-APName=3F_FA_3F_liu_shui_xian-7-RadioID=2-VLANID=31; A user failed 802.1X authentication.Reason:AAA processed authentication request and return 13. %May 25 16:42:22:417 2023 AC_primary DOT1X/5/DOT1X_WLAN_LOGIN_FAILURE: -Username=-UserMAC=0249-f7d9-bd61-BSSID=8c94-6af5-28c3-SSID=test-APName=3F_FA_1F_chang_ku-8-RadioID=1-VLANID=31; A user failed 802.1X authentication.Reason:Received disassociation packet in Userauth state. %May 25 16:42:24:937 2023 AC_primary DOT1X/5/DOT1X_WLAN_LOGIN_FAILURE: -Username=-UserMAC=f09e-4aae-59b1-BSSID=54c6-fffa-9224-SSID=teset3-APName=3F_FA_3F_liu_shui_xian-7-RadioID=1-VLANID=31; A user failed 802.1X authentication.Reason:802.1x user timer timed out. %May 25 16:42:43:571 2023 AC_primary DOT1X/5/DOT1X_WLAN_LOGIN_FAILURE: -Username=-UserMAC=d272-9652-94bf-BSSID=8c94-6af5-2c84-SSID=teset3-APName=3F_FA_1F_wo_lu_fang-1-RadioID=1-VLANID=31; A user failed 802.1X authentication.Reason:Received disassociation packet in Userauth state.
粉丝:7人 关注:19人
用inode试下呢,再检查下AC的配置
这段日志记录了一些802.1x认证失败的事件,可能由于以下原因:
  • 用户名或密码错误:可能输入的用户名或密码不正确,因此无法通过认证。
  • 认证服务器故障:由于认证服务器故障或配置不正确,无法完成用户身份验证。
  • 认证协议不匹配:客户端设备与访问点之间使用不同的认证协议,导致无法进行身份验证。
  • 认证请求超时:如果客户端设备在规定时间内未响应认证请求,则可能会失败
用的inde最新版
zhiliao_ArO1oz 发表时间:2023-05-25
